Apparently very nice 2 liter Zetec Birkin for sale. Gives evidence of recent build, though date is not provided in the ebay ad. $27K buy-it-now. Full road and weather gear. Here's the details from the Ebay ad:
Engine is a 97 ford zetec 2.0 liter completely rebuilt
Raceline sump and water rail
Arp con rod bolts
Birkinsport flywheel, clutch, plate
Stock con rods ,crankshaft,pistons
40thousnads shaved from head
Stock cam,valves,springs
Birkin header
Raceline intake manifold
Raceline jenvey 45mm side draft Throtlle bodies
Raceline 45mm ram pipes
K&N filters
Raceline throttle linkage
Cosworth blue injectors
Circle “C” alternator bracket
Gems Minizeta ECU air intake ,temp sender water temp barometric pressure sender throttle position sender
Raceline wiring harness for gems ecu
Gear box spc fully built standard ratio type 9, 5 speed
Live, straight axle rear end
Raceline adj fuel pressure sender
The car comes with full weather gear that is still in the boxes, it has never been on the car.
Yes the car is very quick. Only flaws are a scratch and couple of stone chips on the bottom of the right front cowl. I will do a light touch up for the new owner. Other than that the car is very nice with excellent paint and for all the world a new car, and never damaged or wrecked.
Car has full wet weather gear. 2,434 .9 original miles with a clear WA title.
And here's the ad:
http://cgi.ebay.com/ebaymotors/Lotus-Super-Seven-Birkin-7-1967-Lotus-7-Birkin-less-than-2500-miles-Superb-/230921558184?pt=US_Cars_Trucks&hash=item35c3ff58a8
It looks like a ZX1 Zetec (used in Ford Contour until March 1998). Nice solid engine and nothing really bad about it, I have one myself in the car. But it is getting harder to find spare parts from the usual sources (e.g. no crankshaft bearing bolts to find anywhere in the world). I bought a complete junkyard engine and disassembled it for my own spare reserve.
The car has the fuse box on top of the passenger foot well, that means it should be newer than about 2001 and has a cleaner wiring than older cars.
