Hettric Posted May 15, 2013 Posted May 15, 2013 Does anyone have pictures of rear exhaust exits? I'm going to have one made up, from what I have read it needs to "turn out" behind the rear tire to keep fumes from being pulled back into the car. Looking for style ideas. Thanks
scannon Posted May 15, 2013 Posted May 15, 2013 I had a rear exit on mine until last month. The exhaust fumes were a problem and that is why I changed it to a side exit. The two rear pipes are factory Caterham units connected by a splitter to a 3" system from the turbo to the back of the muffler. Shortly after this picture was taken I reworked the pipes to raise them closer to the rear body panel. I've never seen a Se7en with a side exit behind the rear wheel. http://www.britishv8.org/Other/SkipCannon/SkipCannon-F.jpg
Hettric Posted May 15, 2013 Author Posted May 15, 2013 Here is one picture I found, I had found another better one, but can't find it again.
scannon Posted May 15, 2013 Posted May 15, 2013 That's kind of weird looking but I suspect it will help with the exhaust fume problem.
MBEARDEN Posted May 16, 2013 Posted May 16, 2013 Mine looks just like Hettric's....but is maybe 1.5 inches longer...painted it flat black...it looks like it might be stock and has totally solved the fume problem...and seems a little quieter.
