Dave W Posted May 25, 2007 Share Posted May 25, 2007 The standard caterham tail light mounting position has the vent hole on top Vs on the bottom side of the lens. What is general practice, Should I keep it vented, will water make it's way in the housing or should I seal the vent hole off. Thanx Dave Link to comment Share on other sites More sharing options...
Dave W Posted June 5, 2007 Author Share Posted June 5, 2007 Found on the UK Lotus seven site. They recomended that you seal the top and actually add a drain on the bottom of each lens. Dave W Link to comment Share on other sites More sharing options...
