slngsht Posted May 26, 2007 Posted May 26, 2007 Who has one here? What brand/feature/price? Anything I should look for or avoid?
R1 Seven Posted May 26, 2007 Posted May 26, 2007 Just make sure to get the probe type. The IR ones only can read the surface temperature which can drop off quickly and give inaccurate results. That is all I have got to add.
WestTexasS2K Posted May 26, 2007 Posted May 26, 2007 I agree the probe type is the only type to use to check tire temps. Surface temps do not mean anything. Now if you are going to check EGT or other temps the IR units work well.
