My headlight switch burned out in the middle of the night. Yikes!
Its one of those multi-prong female white plastic plugs.
Anyways, I had noticed that when replacing the last switch, there was some corrosion in the plug. I tried to clean it up, but obviously that did not work.
Do I have to replace the entire female plug or can I just replace the damaged female pin insert? I'd prefer not to splice something that takes so much current and sits above my right knee.
When I rewired the original mess on my Birkin I bought some new connectors/terminals from British Wiring. The connector with 5 pins is p/n 836 and the connector with 8 pins for the hazard switch is p/n 835. They changed their website but the old catalog is viewable under the "Legacy Pages" tab.
http://www.britishwiring.com/
[/url]http://www.triumphrescue.com/BritishWiring_oldsite/CAT16_19.PDF
Here's a photo of the 5-pin connector.
