Cherik
Sussex, Wisconsin
Interests
Science, electronics, cars, hi-end audio, RC helicopters
Occupation
R&D wireless cardiac and neuro implants
I'd agree with your tuningshop's view on the GEMS. I started with one and had a lot of trouble with it. Quite obsolete. The Emerald and Pectel are popular systems. I switched to a DTA s60, simply because it was the most up to date and interfaces with just about any sensor source. Calibration is straight forward. It's been rock solid for years and a lot of miles. Other DTA 7-users that I'm aware of have been quite impressed with them as well. Esp. the S-series. http://www.dtafast.co.uk/ It allows for a basic startup configuration and develop and refine it as you learn more. It has a "scope" feature which is very useful for map debugging. Their logger is excellent. I sound like a salesman for them... better stop. Still snowing here, 10" down, 8" more to come... ughh.
Well done Mike! ...looks like you didn't even stop to make that picture! Cherik
I'm on my 2nd windscreen as well, same issue with the slow spreading circle cracks. If in the end you land at the dealer option, ask for the "glass only", i.e. without the frame and w/o the screen heater. It's still a 3-layer safety glass! Cherik
Bruce, I guess this is probably for ECU protection. As it is an input, a 1/8watt or 1/4watt will work fine. I'd suggest 'in-line' solder joints with about 1/4" overlap of the wire & strands. Put heatshrink over everything with 1/2" beyond each solder joint. The joints should not be mechanically loaded. How's that machine running? Getting any usable weather up there yet? Cherik
Drive home last night with out a clutch cable was
Cherik replied to DB6's topic in General Sevens Discussion
i've gone through a few of them, but found the key issue was that on long(er) trips when the clutch foot is rested under the pedal, when you bring it back up, it flips the clutch pedal up and starts a kink at that very location. Next time you apply the cable it begins that process. Eventually strands break and it goes from there. Since then I've been careful to not flip up the pedal when pulling back my foot and haven't broken any cables since. A proper pedal stop would be a better solution.. or go hydraulic. I have those parts, but never put them in... The lengths that I have used are 62.5" / 159cm and 68" / 178cm. The longer one doesn't seem to be available in the US. Top pic: "home comer" - with heat shield sleeve still in place Center: long cable, frayed Bottom: spare that I carry in the boot. Both short and long work for a Zetec, but some careful ty-rapping is needed so it doesn't get caught in the belts in front. Cherik http://www.usa7s.com/aspnetforum/upload/1144432031_Clutch-cables.jpg -
..couldn't resist to chime in... with that little hint provided by Al, it just ticked over 77,000 miles. And still enjoying it every time. I have a well running Lotus Esprit, or my wife's TSX to borrow, but when it's time to choose, the 7 is always the 1st choice. Individualistic, sure. There's no need to be average or normal, which I think are the same. Not everyone can afford to own or run one of these, but if you're a gear head and like tinkering as well as driving, this certainly is the best option.. in my humble opinion. I see a lot of that on this list. On daily driving capability, there are certainly a few items that make the car more suitable for longer drives, e.g. deDion suspension, the adjustable seats, the full windscreen, -33dB earplugs, but with those it's pretty exhilarating all the time. Every turn is an opportunity. Normal... never spent much time thinking about what that means, although I think it's suv's, trucks, automatic transmissions, cup holders. I do like to push the envelope on just about everything, just to see what's there and the 7 fits in there perfectly. During 7-7-7 I got to meet some fellow 7-eners, some who build their cars from the ground up! Now, that I have a lot of respect for! The 7 experience is all about what you make of it, and a lot of it is self improvement: driving skills on the road and track, mechanicals, and... explaining things ... Cherik ps: put 2 x 340 miles on it last Wednesday to get to a business meeting... very nice - and if that's not ..uhh... normal, I want more... quickly lock me up before I want to get into my 7 again..... :jester:
hey Bruce, good to hear you're collecting the miles! The season's getting short now... 55F and dropping rapidly... Some ignition light stuff, that you didn't ask for: The charge light has a few functions: 1. it connects the alternator field winding via the regulator (mounted on the alternator) to B+ when the engine is not running, but the ignition is on. When the alternator starts running, it's output will be equal to the battery, via the alternator diode groups. Then the difference between the alt. output and B+ is zero, and the light goes out. 2. it provides an indication that the alternator output voltage is lower than the battery. 3. it uses a 24V low output bulb to also act as a resistor to prevent the alternator from causing "after-run". It needs to be around 80..100 Ohms to work properly. If it's lower, then engine may not shut off... because the alternator field winding continues to feed itself from the small induced field and.. then things won't stop. An after-running cooling fan can cause the same. Given the above: 1. alternator diodes went bad - this can happen when briefly shorting B+ to ground by accident with the engine running 2. bulb is bad, but you already checked that - but make sure it's a 24V bulb, not 12v (as that doesn't work properly) 3. the regulator went bad - if it was a rebuild it may have been compromised... good news is, Autozone carries diode and regulator replacements as I recall for Delco ( if that is what Geo uses). Let me know what you find and I'll come up with more ...... Cherik
nice story! The imagery of being stranded on a dark side road w/o bars on the cell is certainly a tantalizing one... I'm gonna check the batteries on my flashlight. Glad it worked out without too much reconstruction! And you are correct, the piezo pumps can run all the time, but it also depends on the fueling system. They usually maintain 2..3psi pressure, which is fine for Carb systems (2psi is plenty already), and for EFI system they can be used as a low pressure pump to maintain a main tank / surge tank loop from which the high pressure circuit takes it's feed Cherik
..one more thing, If you do find that the cable is too long e.g. 1/16" or 1/8", make sure to grind it off, as cutting leaves a messy end. Cherik
..it's a function of driving a lot of miles without sidescreens... Eventually your senses will re-adjust and you will experience the buffeting as comforting. I found -33dB earplugs (Walgreens) give me a sense that there is a lot less wind in the cockpit. Cherik
I've had some troubles like this a few times and learned of potential causes: 1. cold weather - stiffens the cable and causes it to "jump". It's a square spring coiled cable, thus it is predisposed to this kind of studdering motion. 2. reverse installation - one end of the cable has a collar around it, make sure this is at the speedo side, not at the gearbox. It prevents the inner cable from sinking down, in which case it'll bottom out in the right angle drive and eventually loose touch with the speedo, it'll jump before failing 3. the cable is too long.. check this at the gearbox, by removing the cable from the right-angle drive and spinning it by hand, and have someone watch the speedo. Also, get a feel for how it spins. If it's too long at the speedo side, it'll eventually take out the speedo. Check how deep it goes when the collar touches the speedo and make sure it'll still run free. It's best to take out the speedo and the cable for this test. 4. don't use ty-raps anywhere on the cable. It needs a large smooth arc. If it's kinked anywhere it'll bind up and eventually take out the short 1" cable segment between the drive and the right angle gearbox. Probably more things, but that's what I could think off Cherik
the "oil leak" from the valve cover is from the engine being designed for transverse mounting. In the 7 it's sits for-aft and during spirited driving (esp. on track), the valve cover exit is in the wrong place and it'll throw oil from there. I used to run an overflow bottle from the valve cover hose, and recently added a nice filter box from JEGS with a drain. After each track session, I have to drain a couple of oz of fluid. As far as the ring gap measurement, the top-bottom difference and the lack of a visible honing pattern, it looks like well worn bores. I'd suggest to compare the cost for another block (although by now all the Contours will be "aged"), or get an overbore and fresh pistons. A 1mm ring-gap and the .3mm difference suggest you're well past the service life. Most of the bore wear is where the greatest combustion and lateral pressure exists, which is about 10..15% from TDC. Maybe redundant is a check with a bore micrometer for bore ovality left right vs front back to confirm the wear. As was mentioned, the piston skirts show some scuffing, which could be from a lot of miles or a few Wisconsin cold starts with old / thick oil. Cherik
just about any surface on the bulkhead will conduct heat. I solved that by using heavy duty velcro (Radio Shack has it), to prevent heat conduction. One issue during trackdays is the higher revs, and subsequent higher load on the ignition and injector drivers because of the number of pulses per second that it results in. I used to have a GEMS unit, which had no real heatsink and it eventually died. Repeated cut-outs from overheating will eventually damage the drivers. I now have a DTA unit on two of those velcro strips and it's been flawless. Cherik
Congratulations Bruce! I saw the pics of your car in motion elsewhere on this forum. The car is looking very sharp! Let the fun begin! Cherik
no-one warned us, but then, would we have listened? Se7eners generally don't listen well to warnings anyway, like the warning about the $'s and time, the ridiculous explanations to the roadpatrol as to why you did what you did... it just goes on... But, no-one can truly explain to a non-se7ener how much fun this continues to be :thumbs:
