Donnie
Everything posted by Donnie
  1. Need a diagram utilizing motor terminal numbers (not colors), switch terminal numbers (35927) and relay terminal numbers. I wired it without the relay and it blew fuses. Switch is probably a knock off. Thanks in advance.
  2. Used the wrinkle finish over masonite. Worked great. Easy to cut with jig saw.
  3. Interesting. Love the wrinkle paint finish. Thanks.
  4. Thanks for the input. Will consider options and share.
  5. Still seeking the perfect dashboard. Aluminum that is thin enough to cut is too flimsy. Anybody found an acceptable medium?
  6. I can't wait.
  7. Funny. You had plenty of erroneous advice to give when my Series 1 was on BAT.
  8. In your view, on what circuits are relays mandatory? Thanks in advance
  9. I have a 1981 Rotus with Toyota 2TC engine. Looking for a source for headers.
  10. I've listed a single 45 DCOE carburetor on Ebay. Spanish manufacture. Removed from a 1275 BMC race engine. $350 buy it now.
  11. Compared parts lists. Keep in mind mine is a 1981. The above list is dated 1991. The only differences in my list are the addition of the following: Front turn signal Harley Davidson (built into rear view mirrors) Speedo cable 83710-29345 Spring Wrapped Brake Hoses (Toyo) 90947-02317-86 Stop Light Switch (Big A) 325-6 US14 std Radiator 21" Mazda
  12. As far as the parts list; my list overlaps but is not the same. I'll compare and come up with one complete list. As to the toggles; Rob (the previous owner) showed me they all worked but I wasn't taking notes. I'll check them, figure it out and get back. I have a set of 40DCOE Webers coming tomorrow that I want to install. Anybody want a set of Mikunis?
  13. @Marek I have a list of virtually all components and their stock numbers,
  14. Is the Rotus group active? I just purchased one with the 2TG engine.
  15. Thanks. Probably best in the long run to just get a new complete kit. Cheers
  16. Not sure what you mean about not working on a 7. They will need to be rejetted regardless of the application. I have a seven clone with a 2000cc Toyota TGE engine.
  17. Please respond. Need to know if still available. Thanks.
  18. I'll take them if you still got. Don Freeman
  19. My Seven has 2- 40PHH Mikuni Solex sidedrafts. Once choke is reduced,the engine dies. Cannot maintain RPM less than 2000 RPM. Carbs were rebuilt recently. Tempted to go to Webers. Any thoughts? Thanks in advance. Donnie
  20. Thanks. Already got a car in mind. Just nervous about hitting the "BID" button.
  21. Considering importing a 7 from Canada that was once registered in the US. Picking it up myself would be difficult. Anyone with experience have any tips. Thanks.
  22. I have been corresponding with a consignor in Montgomery, AL. about a 1994 Caterham he has listed for $17,850. Hmmmm. Further investigation found that the car, then located in Las Vegas, listed on BAT in 12/22 and did not meet reserve at $28,000. With the help of Google I found the same car for sale in MInnesota. Chassis number is SDKRDKANSQ0301600. Buyer beware!!!
  23. Had 2 responses but no visits as yet. Give me a call if you chose to visit. Thanks. Don
