mel kuipers
    Arizona, Lotus is in Montana
    2004 WCM Lotus 7
  1. The records from the builder, was about 1400 lbs, which I assume included him in it.
  2. Mel and Judi Kuipers 650 North Hawes Rd site 2829 Mesa Az 85207 1 (406) 223-1515 rosebud_59047@yahoo.com Updated information as of 6-19-2024: OE muffler that was replaced, is available. Look at the magazine picture for how it looks. Car it titled as a 1968 Lotus, due to the steering box being off an MG. That age qualifies it for permanent liscensing in most states. I carried auto insurance with Haggerty Insurance. They were easy to work with and it cost about $350.00 a year with $1000.00 deductable. Value of the car is negotiable with Haggerty, but of course the more you insure it for, the higher the premium. I declared value for insurance purposes as $25,000.00. VIN # is WCM036 Current title is shown below in pictures FWIW her name is Lucille, after the George Kennedy line in Cool Hand Luke: "Anything so innocent and built like that, just gotta be named Lucille." 6-4-24 WCM Lotus 7 History and Specs My WCM Ultralite Lotus 7 S2K, was developed as a kit car, by World Class Motorsports (WCM) in 2004. WCM only made 50-100 of these cars. They are a bit wider than other kits, which accommodates larger drivers. Jerry Edden of Missouri, was the first owner, and did the construction. The drive train is a 2003 Honda S2K engine and 6 speed transmission, delivering 240 hp, with a 9000 rev limit. The engine at the time of the build had 1175 miles on it. The differential is a Subaru WRX limited slip differential. Jerry made very few modifications to the original kit. The car was written up in September 2005 issue of Kit Car Magazine, being featured on the cover. A copy of that magazine will convey to any future owner of the car. The article contains the test data from a drag strip where Jerry turned a 12.69 quarter mile run, on street tires. I bought the Lotus from Jerry in August 2017, and modified the car in a number of ways: 1. The steering wheel was raised 3” from below the dash, to through the dash. At 6.4 and 250 pounds, I needed the extra room for knee movement. It now fits me perfectly. 2. The dashboard was a padded one, and was replaced with brushed aluminum. That gives a more race car appearance and also allowed for moving the oil pressure and temperature gages to a more visible area after the steering wheel relocation. 3. I purchased 4 steel 15” wheels and spacers for the Lotus. They are 8” wide and specifically accommodate Hoosier racing tires. They go with the Lotus. 4. A three place draft vent was installed in front of the passenger compartment, and right behind the headers. This vent system significantly lowers the temperature in the car. 5. The 16 gallon aluminum gas tank the width of the trunk, was replaced with an 8 gallon plastic fuel cell mounted on the passenger side of the trunk. That significantly reduced weight, shifted the weight to the right side (off setting some drivers weight on the left side). Since my primary use of the car is autocross, excess fuel storage was not important. 6. A quieter muffler was added to comply with SCCA rules, and help avoid being too loud for neighbors of autocross venues. 7. There was a slight valve cover rub on the fiberglass hood. To fix that, Cadillac engine mounts were installed, which lowered the engine by 3/8 inch. That stopped the rubbing. 8. The interior of the trunk was thin wood and plastic coated cardboard. Neither of them were effective or durable. Those surfaces were rebuilt in thin aluminum. 9. Front brake pads and shocks were replaced in 2023. 10. A Miata MX-5 sway bar was installed on the front in 2022. That all but eliminated lifting of the rear right wheel, on a hard right turn. While auto crossing, there is no understeer, and over steer only happens when trail braking. The car is amazingly well balanced. 11. The bug eyed headlights were replaced with LED lights. That saved weight, and made the car still comply with street legal requirements. 12. All normal maintenance was performed. Since I have only autocrossed it about 200 miles a year since 2017, there was limited oil wear. The odometer has about 12600 miles on it at this time. 13. Also available with the car is a 7x14 foot enclosed Haulmark trailer, for trailering the car to events. I modified the rear entry to better accommodate a wide car like the Lotus. I also added an electric winch to open and close the rear door. The trailer will first be offered to anyone buying the car. If that buyer does not want the trailer, I will sell the trailer separately. The trailer comes with a 2 5/16" ball, load leveler hitch. It is wired for brakes, and the tires were new in 2020. They have less than 2k miles of wear on them. 14. The Lotus is currently living in Livingston Mt in a fellow autocrossers shop. I reside in Mesa Az, and fly to Mt to race. I have driven an F1 car at PIR (Phoenix International Raceway), and this car is every bit as much fun to driven as the F1 car was. 15. The car has a full tonneau cover, same materiel as the pictured boot cover. It is fully water proof, and keeps the cockpit and boot completely dry. Asking price is $25k for the car and $5k for the trailer. If this might check a box on your list, give me a call or text or email. Let's talk. Owning and driving this car has been a fun dream come true. Now I am 74, and getting in and out of the car is becoming more difficult. So I am in no rush to sell the Lotus, but it is time to move on to my next adventure. Mel Kuipers
  3. I have a 2004 WCM Lotus Seven, with a 2003 Honda S 2000 engine and transmission. The differential is Subaru. I have owned it since about 2018, and drive it less than 200 miles a year, all autocross. The odometer says 12500 miles total. It has been a fine car, but at 6.4 and 260 pounds, and 73 years old, it is a bit difficult to get in and out of. Currently the car is in Livingston Mt, and I tow it in a 14' enclosed Haulmark trailer. Trailer is available with the car. If you are interested, give me a call or text at 406 2231515. Mel
  4. Jerry....have just been talking about you I think....see above....how are you?....had a great season (as in my best FTD performance yet)....Mel
  5. SanderGA is exactly right...mine was built by Jerry Eddens in Mo in 2004 ...picture in in my icon....Mel
  6. I have a 9 year old set of Falkens. They have lots of tread on them, and are not weather checked in any way. Looking at them only, they would sell for new. In autoX they are 3 seconds slower than new ones. Often 4 seconds. (I know this because of cording a set oh Hoosiers but not having the replacements in inventory). I try to replace tires at 3 years to insure maximum performance. Oh, and I put 209 miles on my 7 this year.
  7. I have a Subaru LSD, and don't get severe oversteer, but do lift the inside rear wheel on tight corners. That causes the inside rear wheel to spin. I am looking to add a front sway bar to keep the front flat, and thereby keep the rear flat. The only time I get oversteer is when I trail brake or engage the throttle too quickly.
  8. I am in Mt now, but will be in Mesa in January.....if you still have the bar I would love to look at it....my phone is 406 223-1515....lets be in touch
  9. Thanks Anker. My ride does not have a front or rear sway bar, but does have an LSD. In a hard corner, it lifts the inside rear tire, and the LSD wants some traction to limit spin. So I am looking to find a way to put a sway bar on the front. That should limit wheel lifting.
  10. I have a 2004 WCM 7, and in autocross will pick up the inside rear wheel when cornering tight. That of course leads to wheel spin. A friend of mine with a Westfield, says a front sway bar would help hold the rear flat and down. I would appreciate any advice from anyone who has achieved that install. Thanks, Mel
  11. I bought the sister of Paul's WCM Lotus 7. Bought it two years ago from his friend Jerry in St Louis. I am 6 ft 5 inches, with size 13 shoes. I had to raise the steering wheel 3 inches, and make the foot well 1/2 inch wider by removing a cardboard side wall. Those mods were really quite simple, and now I autocross the car with great passion. Given my size, I had the same issues with footwell room, but with relatively easy mods, I am now having the most fun I have had with a car. Oh, and I race in wrestling shoes. Only 4 inches narrow. I can't drive my friends Westfield 7, because when I put either foot down it hits two pedals. If you are wanting a 7, and above average in size, Paul's car is worth a look.
  12. Have purchased many tires from Tire Rack over the last 12 years.....they have always done an excellent job for me.....their advice was spot on also....
  13. the thread below talks about dampers....my question is what adjustable dampers fit a 2004 WMC Ultratlite?....also, my ride does not have a front sway bar---what is the best way to add one?....I will be auto Xing the car and need the back to follow the front....Mel
