ChuckM
Manchester, NH
Se7en
1984 Caterham S3, Ford Super Sprint, LHD, solid axle
Four free shocks, 1989 Caterham for just the UPS fee.
ChuckM replied to ChuckM's topic in Parts For Sale / Wanted
The shocks are gone! -
MV8, Thanks for the clarification about the need to a second relay, I will pickup a second relay to finish my project. Thanks again!
I’m also attaching a picture of Derale wiring instructions (diagram #8) for comment. This diagram indicates only one relay. There are TWO 12V Switch Power or Thermostat connections, can both of these be connected to the heater fan switch?
MV8, I should be paying you a consulting fee! I am attaching a picture of my installation which has only one relay, I’m sensing from your diagrams that I might need two?.
MV8, Auto electric is not my forte’. So are you thinking I don’t need the relay and I can just plug into heater power source?
Steve, you must be a pro! Thanks very much the wiring diagram, my own installation does have a relay, a 30 amp fuse and a manual switch (I used the wiring and switch for the heater fan as an expedient). With everything wired I can turn the fan on low speed then high speed, but when I turn the ignition off the fan keeps running? It must be something simple so I’ll keep trying different things. Thanks again for your help!
Andy, Your name appears when you respond to my post? This is a 2 speed fan, but when I connect the red wire to power I do get both low and high speed cooling, but the fan continues to run after I turn the ignition off? Obviously auto electricity is not my strong suit!
Andy, I do have an IR thermometer so I’ll try that tomorrow. The radiator is not leaking or hissing so it could be a faulty gauge. Brilliant!
Andy, The temperature gauge is in Celsius, there’s a 90, then a hash mark (not quite half way to 140) then 140 Celsius. It warms to 90 C then creeps up to the hash mark, that’s when I head home. There are several things that might contribute to the problem such as air in the cooling system, bad water pump or old Marston radiator. I’m open to suggestions and recommendations. I am not a professional mechanic! Thanks
I’m a first-time 7 owner, I bought my car in March 2022 and have been doing a fair amount of repairs to include tires, shocks, springs, clutch cable and a high output radiator fan (1460 CFI) to name a few. One thing I can’t figure out is why the car still runs hot especially went I push it? I think the previous owner removed the thermostat, so that’s not something I can experiment with, fan belt looks new, there’s a minor fluid leak which might be the water pump, but I’m not sure. I don’t think it’s a head gasket issue so I’m thinking water pump? Any sage advice would be appreciated, thanks.
WTB Bushings for solid rear axle Caterham (1984)
John, Thanks for helping out, but I have ordered a complete set from Redline Components in the UK. Thanks again for helping out! -
MV8, The folks on this forum are fantastic sources of information, thanks so much for your help tracking these bushings down! Regards -
Thanks and will do!
