Biography
Hi Guys, Dave here, I am located in Queensland, Australia in an area they call the "Sunshine Coast". I am a 68 year old supposedly retired, ex Mechanic, ex Police officer and current small business owner. My car is a 2014 Roadsport 175, green with a yellow stripe highlighted with white side stripes. I couldn't say no when i first laid eyes on it.
Interests
Cars, metal detecting and driving
Occupation
Retired, supposedly!
Se7en
Caterham, Roadsport 175
727 profile views
The steering column doesn't really have much telescoping effect, maybe an inch or so if the clamp slips. You can get an "energy absorbing" upper steering shaft that looks like a large flower petal that the steering wheel attaches to though. Lets face it if you have an accident in a Caterham with any thing solid you are going to loose. the steering column will be the least of your worries.
Hi Slonie, You cannot fit the bush first if you are still going to use the original upper steering shaft with the steering lock. The steering lock block with the slot in it for the lock is the same diameter as the bush. However if you change the upper steering shaft to the detachable steering wheel type without the steering lock you can fit the bush first. Cheers
Apologies, I found the post i was looking for, there are only 30 pages. Makes interesting reading if you have a failed Titan though. https://www.caterhamlotus7.club/forums/topic/263872-bmwtitan-lsd-viability/#comment-263446
Drakman started following 15” Wheel offsets , Failed Titan Limited Slip Differential , *Sold* 15in Caterham 10 spoke wheels with tires. Anthrite Dark Silver and 5 others
This happened to my 2014 Roadsport as well. I did the usual research and initially i wanted a OS Giken (Japanese] diff center for the BMW diff, i couldn't get one at the time, i do believe they are available now though. I ended up getting Ollie at RRT in the UK to build me a Drexler to suit the Caterham. I'm not sure i can say this here, delete if not allowed, the Caterham Lotus 7 forum in the UK has 60 or more pages of info on Titan diff failures and lots of updates about the best alternatives. Crap, it says there are 802 pages not 60, must be posts? https://www.caterhamlotus7.club/search/?q=Titan Diff failures&quick=1
Hi Carl, Thank you for your response, I understand that Jenvey say the best place for the injectors is in the manifold/ITB's. Do you know if the gain would be worth moving the injectors? Dave
A quick call out to the brains trust here, Is there any measurable improvement (HP, Torque or drivability) obtainable by moving the fuel injector location from the cylinder head to the ITB's with Jenvey ITB's in a Duratec 2 liter? As an aside is there any difference in using extended injector tip injectors. I currently have Bosch green giant injectors located in the cylinder head, i have been thinking about going to ITB located injectors so i have to change the injectors to a shorter version to clear the air filter and the Bosch 380 cc high impedance, 12 Ohm extended tip version has been recommended. Is there any information/data, dyno results either way on this? Cheers Dave
13" Kodiak Lightweight three piece wheels
Drakman replied to Doug7L's topic in Parts For Sale / Wanted
Thank you for the information Doug. -
Hi Doug, Do you know what just the wheels weigh without the tires? Did you run cycle wing front guards or clamshells? If cycle wing type did you have any trouble with tyre clearance with the wing stays? Dave -
Hi Guys and Girls, I am looking to experiment a bit with wheels and tyres. I have a set of the original Minitaur 14 x 6 inch wheels that came with my 2014 Roadsport and i recently purchased and fitted a set of 13 inch x 6 and 8 inch K&N Caterham wheels. I am trying to find a set of Caterham 15 x 6.5 inch Orcus 6 spoke wheels to fit my 2014, De Dion Caterham. I would prefer to find a set of well used rims as i am going to powder coat them anyway so pristine wheels would be a waste. Cheap is better because they will cost a fortune to ship out to me. Has anyone here got a set they aren't using and want to sell? Thanks Dave
Just a thought, take the fuel cap off and try, if the cap is vented and the vent blocks it creates a vacuum in the tank and a no fuel flow issue results. The other thing is a few years ago there were quite a few fake NGK spark plugs being sold, mostly through Ebay, Chinese copies that produced the symptoms you are describing. A quick rough and ready SU flow check, take the float bowl top and the dashpot and piston off, while looking down into the top of the carb pour a little fuel into the float bowl, you should see the fuel overflow out of the top of the jet. In fact if the float level is right you might even see the fuel in the jet just by rocking the car, the fuel level will obviously be the same in the bowl and the jet. Dave
Lol, that old saying about not letting my wife sell my toys for what i told her they cost applies here.
I hope this will wake the 2 liter duratec engine up a bit. I love a good jigsaw puzzle, i guess it all goes somewhere.
Hi, I use this when comparing wheel and tyre sizes. https://www.wheel-size.com/calc/?wheel1=185-65-14X6ET23&wheel2=185-55-13X6ET23&fcl=50mm&scl=50mm&wcl=30mm&sr=0mm
Yes, just brace yourself and keep applying more pulling power, I'm 6' 2" and i have been weight training most of my life and i had trouble with mine. You need to get some lubricant around the outside of the bush where it sits in the chassis/dash tube. I must stress though that my car is a 2014 SV model, I don't know if your set up is the same. You should be able to see the steering column bush start to bulge out as you apply pulling force, be warned when it comes out you might end up on your back. As long as the key is switched to unlock so that the steering can turn the lock should not impact the column. Good luck Dave
