CharlesG
Everything posted by CharlesG
  1. Unless you have one of these.
  2. The tail housing would be difficult to remove while in the car. I would try MV8s suggestion first. Welcome to the Vauxhall engined Seven group.
  3. Sort of. CA allows 500 cars per year to be registered under the SB100 process. As you register your car, you are assigned a sequence number. I’m working my way through the system now, so I’m learning quite a bit about the process.
  4. It’s a 2 liter Vauxhall DOHC.
  5. This is my pedal box. I have no problem with the clutch pedal, but I will have to modify the brake pedal.
  6. That will be my plan as well for now. That rod is most likely a ‘stuck throttle release’. If the throttle sticks open, you could press up on the rod with your toe.
  7. Hello, I am finally an owner of a Se7en. It’s a 1994 Caterham HPC. Yes, the one from BaT. I just picked it up yesterday, and am spending my time getting to know the car. First item on the to do list will be a quick release for the steering wheel. After that, I will modify the pedals to allow my size 13 feet to work the gas and brake pedals separately. Charles
