Locofinn
Everything posted by Locofinn
  1. Photo update. http://www.locostusa.com/forums/download/file.php?id=29390&t=1
  2. I figure about 600 hours over 4-1/2 years. Check out the video in the Seven Videos section. It worked very well. Needs some tuning but nothing major. It will never be truly completed if you know what I mean.
  3. No major issues on my scratch built Seven. This was my first drive in the car at a track night at Gingerman Raceway in South Haven, MI last night with South Bend SCCA Region. Taking it easy to see what falls off. Nothing fell off!!! [url=http://youtu.be/3zvp27XIuSQ][/url]http://youtu.be/3zvp27XIuSQ
  4. Update photo before the first track day. http://www.locostusa.com/forums/download/file.php?id=29390&mode=view
  5. SCCA will accept a flexible SFI rated transmission blanket. RCI sell one.
  6. 2013 Spectre Super 7 Steering · Coleman 2.5 quick ration manual rack & pinion · 10” steering wheel with Coleman quick mount Brakes · Front Ford stock car type vented disc with GM metric calipers from Speedway · Rear Mazda RX-7 stock disc · Dual Wilwood master cylinders with remote cockpit adjustable balance bar. · Neal CNC pedals · Combined Nylon and braided steel lines · Hawk Pads Ignition/Fuel · Weber 48IDA downdraft mounted on Racing Beat intake · Holley electric fuel pump with hicapacity filters and fuel pressure regulator · 3 gallon RCI aluminum fuel cell · All brained stainless lines and AN fittings · Mallory HyFire 6AL dual CD ignition for trailing and leading wasted spark set up with revlimiters. · Innovative Tech LC-1 Air Fuel sensor mounted in header with heat sink and digital A/F gauge · Lightweight battery mounted in boot · 8 circuit basic electrical harness and fusebox Safety/Interior · Kirkey aluminum race seat · G Force 5 point SFI harness with camlock with arm restraints · Autometer & Rebco Pro Comp gauges and water resistant switches · Aluminum .040 sheet tunnel cover http://www.locostusa.com/forums/download/file.php?id=24377 http://www.locostusa.com/forums/download/file.php?id=22846 http://www.locostusa.com/forums/download/file.php?id=22843
  7. 2013 Spectre Super 7 Driveline · Mazda 12A rotary with carb (stock for now, Bridgeport to come later) · 2” Custom 2 primary header design .180 wall mild steel and titanium wrap · Stainless Racing Beat 3” presilencer, to 3” Racing Beat stainless muffler · Oil system with 2 qt Accusump with factory oil cooler and manual valve all AN braided stainless lines · Cooling Honda Civic 3 core radiator with manual electric Spal fan · Mazda RX-7 stock 5spd gearbox & clutch · Custom driveshaft fabricated by Action Machine, South Bend, IN · Mazda RX-7 GSL live axle with LSD http://www.locostusa.com/forums/download/file.php?id=22821&t=1 http://www.locostusa.com/forums/download/file.php?id=22848 http://www.locostusa.com/forums/download/file.php?id=24380
  8. 2013 Spectre Super 7 Body · Handmade .040 half hard aluminum sheet panels · Nose cone fiberglass S2 repoduction · 10” Front cycle fenders from Coveland · Rear fenders handmade .040 aluminum with integral rear spoiler/boot deck · Dash Gauge Plate 1/8” 5052 aluminum plate · Aero Belly pans .040 aluminum http://www.locostusa.com/forums/download/file.php?id=21088&t=1 http://www.locostusa.com/forums/download/file.php?id=21565&t=1 http://www.locostusa.com/forums/download/file.php?id=20682&t=1
  9. 2013 Spectre Super 7 Suspension · UB Machine Front lower strut type with spherical bearing mounts to chassis and upright (Asphalt stock car type design) · Speedway Front upper wishbone swedge tubes with spherical bearing mounts to chassis and std ball joint to upright. (Asphalt stock car type design) · Mustang II spindle/uprights · Front coilover aluminum single adjustable shocks with 350 lb springs · Rear custom 3 link trailing arm live axle with swedge tubes, panhard bar and spherical bearing mounts to chassis · Rear coilover aluminum single adjustable shocks with 90 lb springs · Diamond spun steel race wheels custom offset 13” x 10” rear and 13” x 8” front · Hoosier race slick tires rear 22” x 10” x 13”, front 20.5” x 8” x 13” R25B compound http://www.locostusa.com/forums/download/file.php?id=7872 http://www.locostusa.com/forums/download/file.php?id=6267
  10. 2013 Spectre Super 7 Chassis · Custom scratch built “Book” sized Mig welded with Std Mig Mix Argon/CO2 · 1” 16ga mild steel square and round tube with 16ga stitch welded floor and various extra strengthening tubes. · 1½” .095 wall DOM Seamless Roll hoop front and rear integrated into frame per SCCA Solo rules and SCCA GCR rules · 2” x ¼” steel drive shaft hoops (required for Modified SCCA rules) · Completed bare frame is 240 lbs http://www.locostusa.com/forums/download/file.php?id=8636 http://www.locostusa.com/forums/download/file.php?id=8635
  11. Hello all! I've been working on this scratch build Seven clone off and on for 4 years. This is my first attempt at building a car. This car will only be used for autocrossing and trackday fun. I'm only one month from the first track event and cannot wait to drive this. I want to share a few pics to show you where I'm at in the process. It may be a crude beast but it should be fast when I get the full race motor in it. It weighs a bit heavy at 1,320 lbs wet right now but I can work on that. http://www.locostusa.com/forums/download/file.php?id=28499 http://www.locostusa.com/forums/download/file.php?id=28498 http://www.locostusa.com/forums/download/file.php?id=28497 http://www.locostusa.com/forums/download/file.php?id=28496
  12. I used prefabed parts from AA Mfg. .25" x 2" hoops mandated by SCCA mod rules. I added 1.8" plates to the sides also.
  13. http://stores.shop.ebay.com/Race-Tires-USDRRT__W0QQ_armrsZ1 70% tread @ 7% cost He ships UPS
