lambobuilder
    Austin, TX
  1. Now listed on eBay https://www.ebay.com/itm/293748516376
  2. Details: Lotus Super 7 Replica.Previously featured in Reincarnation (https://www.rcnmag.com/garage/supersize-super-7)A unique one of a kind Super7 with a Honda S2000 drive train. 2 liter 240 HP VTEC engine coupled to an S2000 transmission and rear end. Even has the S2000 instrument cluster. Willwood Clutch and Brake assembly, 10-gallon fuel cell, electric fuel pump, 1993 Volvo radiator and Mustang II steering rack. Has both a fuel cutoff switch and an Anti-theft switch to prevent engine starting if in off position. Exhaust system includes muffler and catalytic converter with both O2 sensors. Car has Elbrus 16” rims with Kumho 205/55 ZR16 on the front and 225/50 ZR16 on the rear. Front brakes are GM and the rear are Honda S2000.The chassis is a custom tube chassis based on McSorely 7 442 design. Floor and cockpit aluminum sheeting while the body is constructed from metal framing and fiberglass. Custom seats modified to fit the frame. The driver side adjustable and the passenger is fixed. Roll bars for both driver and passenger are integrated into the frame. Paint is Electric Yellow. Car is licensed, registered and insured in Texas as a "Custom Vehicle" which makes it exempt from inspection.
  3. Selling this project to start another one. Details here: https://www.youtube.com/watch?v=4f0XPXZEIhE
  4. https://www.rcnmag.com/garage/supersize-super-7 Full video of the build is
  5. Finally finished the project. Video of complete build can be found here.
  6. I believe a Tahoe if I remember correctly.
  7. Discovered part of the issue was the car and part of harness was from Canada, which requires Daylight Running lights. Hi beams were putting out 6 volts to hi beams to turn them on when driving. Finally just added a new relay and activated from the high beam switch on column.
  8. I am using S2K engine and wiring harness but am not using the S2K headlights. trying to connect standard Hi/Lo connection to wiring harness. Looking at schematics, the S2K harness relies on their headlight DRL module to activate hi beams. Has anyone made this work on their car? The current plug in will activate low beams only. This is car http://www.usa7s.net/vb/attachment.php?attachmentid=13303&stc=1
  9. Created my own body panels except for nose which I integrated into hood. http://www.usa7s.net/vb/attachment.php?attachmentid=13113&stc=1http://www.usa7s.net/vb/attachment.php?attachmentid=13114&stc=1http://www.usa7s.net/vb/attachment.php?attachmentid=13115&stc=1
  10. http://biareview.com/ http://anztheme.com/ dịch vụ thành lập công ty trọn gói tư vấn pháp luật dịch vụ kế toán uy tín đào tạo kế toán chúng ta có thể nói là một trong những thế gia lâu đời nhất trên Khung Võ đại lục, nghe nói, tổ tiên của đời thứ nhất chính là cách đây đã hơn vạn năm. Mà chúng ta đời đời truyền lại công pháp Phần Kiếp Tử Diễm chính là đệ nhất tuyệt học trên Khung Võ đại lục, lúc ấy, chỉ cần ngươi mang họ Tư Đạt Đặc, là có thể làm mưa làm gió trên đại lục rồi!
    - Công pháp Phần Kiếp Tử Diễm? Công pháp gia truyền của chúng ta không phải là Luyện Khí Quyết sao?
    Dịch Vân nghi hoặc hỏi.
    Môn La cười ha hả:
    - Cái mà ngươi đang gọi là Luyện Khí Quyết, thật ra chính là công pháp Phần Kiếp Tử Diễm đó!
    - Cái gì! Kh
  11. I will not be able to use the scuttle I got from Kinetic Vehicles. Paid $199, will sell for $150 plus shipping. Shipping could run around $50 but would get quote based on buyers address.
  12. Engine now in. All lines run. Need to work on wiring to get it running but progress is being made. https://lambobuilder.wordpress.com/2015/11/21/engine-in/
  13. Ok. Been able to do some work on the car. Managed to get the frame painted and floors installed. Biggest thing is I made removable side panels started out with Fleece material. Will finish with body filler later but it was a cool process and has all kinds of possibilities for one off's. https://lambobuilder.wordpress.com/category/super-7/
  14. Widened cowl and installed radiator Details on my blog https://lambobuilder.wordpress.com/2015 ... ront-cowl/
