biquet1957
Everything posted by biquet1957
  1. Hello I also have a live axle on my Birkin. This is a warner Borg M68 with a ratio of 4.11. I just fit a Quaife diff ADT home was ordered directly from them. It is not easy to settle the problems of thickness to avoid differences. I am doing this work. http://datsun1200.com/modules/mediawiki/index.php?title=Borg_Warner_Differential
  2. hello jackal This kit is not for my Birkin ,My birkin is driving on the right ? my steering column is in the way! bye peter
  3. hello thank you for the information But my engine is a 2.0 zetec water pump is different and the timing cover is different. I think buying only the alternator power to the bindings myself. For now the 70 A of the left engine that mepose problems. I guess 40A enough for the birkin. Thank you again. Peter
  4. Hello Jackal I'm having trouble with my alternator on my 2.0 zetec is below left. Can you give me the information about your brand alternator model and amperage. thank you again peter from Belgium
  5. Auto Technica ATR 3350
  6. Still some photographs http://nsa28.casimages.com/img/2011/11/05/mini_111105071948830138.jpg http://nsa28.casimages.com/img/2011/11/05/mini_111105072416425617.jpg http://nsa27.casimages.com/img/2011/11/05/mini_11110507245488351.jpg
  7. Hello When the rails are placed on the wrought iron reinforcement as onto the photographs, it is possible to fix the bolts of front while drawing on the rail behind. On the other hand for the bolts of behind, it is necessary to place the bolt in the rail before positioning it on the bottom. The lower rail is right to receive the bolt for key of 13. And when you to tighten by lower part it does not turn. My English is very bad, but I have to dismount the seat and the photographs speak. There are 4 bolts by seats but the seat is fixed on the new steel cross-pieces. Peter http://nsa27.casimages.com/img/2011/11/05/mini_111105071602599861.jpg http://nsa28.casimages.com/img/2011/11/05/mini_111105071704681718.jpg http://nsa28.casimages.com/img/2011/11/05/mini_111105071752614284.jpg http://nsa27.casimages.com/img/2011/11/05/mini_111105071834955558.jpg
  8. hello What you see on the photographs it is the seat assembled without the bottom. The bottom is photographed on the cap. And under the rails there is a weld steel part between the cross-pieces to reinforce the bottom. And for not that the seats go down with aluminium and the rivets. There are 6 screws to fix the framework of the seat on two rails 3 on each sides. And above to pose to you the bottom of the seat, simply deposited. the photographs are not very explanatory I did not have much light. Bye Peter http://nsa28.casimages.com/img/2011/10/25/mini_111025104428562646.jpg http://nsa28.casimages.com/img/2011/10/25/mini_111025104538260789.jpg http://nsa28.casimages.com/img/2011/10/25/mini_111025104618359454.jpg
  9. Hello I spoke about sudures not to fix the rails on the aluminium bottom. The fact of placing U in lower part and of fixing them with rivets is a good thing but increases the risks to hang the bottom. the aluminium bottom is rivetted on the frame and the weight of the seats and the pilot pushes on the bottom. They are only rivets. I preferred welded two dishes per seat to reinforce I will place photographs later . Peter
  10. Hello It is necessary to buy the seats with the rails. The rails birkin are dismountable thus, to remove the rails, to weld two steel 50mm/4 mm by seats between the cross-pieces. Then to place the seats to trace, drill the 4 holes by seats and to fix the seats. I put 1 hour to place the seats in Birkin. bye Peter from Belgium
  11. Hello it is Peter of Belgium. I have a birkin of 1999 and I changed the seats of origin very can comfortable. I replaced by seats for S3 caterham out of leather they are extraordinary. The bottom is dismountable of continuation I have only to remove old fixings and to weld 2 reinforcements by seats to reinforce. for me best the solution. Bye Peter http://nsa21.casimages.com/img/2011/10/19/mini_111019100806548399.jpg http://nsa21.casimages.com/img/2011/10/19/mini_111019100857992004.jpg
  12. Hello the guy. I believe that RZEMPEL was right but I have more precision. It is many wipper arms of golf two of 1985. But of the modified back. With wipper blades of Toyota corolla 1992 1993. Still thank you for the information hello for Belgium. bye Peter
  13. Hello Rzempel I take note of your information well. I must have easy to find and compare here in Europe. In more I have a friend who has a golf GTI first series thus I control and I confirm soon. Still thank you for this help. Bye peter
  14. Hello It is very comic all that. But my wipper arms and wiper blades come from another car. They were transformed. I must approve my BIRKIN in Belgium and I seek these parts. The arms were recut, folded and the blade are shortened. See the photographs thank you for your assistance. http://nsa28.casimages.com/img/2011/10/08/mini_111008032544880494.jpg http://nsa28.casimages.com/img/2011/10/08/mini_111008032750789744.jpg http://nsa27.casimages.com/img/2011/10/08/mini_111008033018499474.jpg http://nsa27.casimages.com/img/2011/10/08/mini_111008032920597963.jpg
  15. Hello the guy Just a small question. Can you say to me which is the source of the wipper arme and blade for a birkin S3. It is possible to find these parts on other cars or they are manufactured exclusively for Birkin.??? Peter from Belgium Thank you for your answers
  16. Hello from Belgium I tested relate to my birkin they are adaptable on the inferior part. On the other hand on the caterham the hinges are has outside and with two screws by hinges. Thus it would be necessary can be to buy two hinges caterham. On the other hand I did not test with the roof because I do not have any yet. Bye Peter
  17. Hello Mike I hear to you of Seats. I have just made a choice for my seats of origin birkin, not very comfortable slipping and especially hard because not much of Foam the interior has. And to finish I have to order seats caterham for leather S3. A true quite especially constant happiness under the thighs and in the back and very flexible I recommend this seat. I tested much pure me they is ideal. I add photographs to prove that it goes well in the car. Bye Peter http://images4.hiboox.com/images/3411/5ea184c3a4c41bfe906e16a55b61fd51.jpg http://images4.hiboox.com/images/3411/cd4499761ff2d3d03732e5c38a978912.jpg http://images4.hiboox.com/images/3411/55d38f297be129a48f78ce24e6a882b3.jpg
  18. Hello mike I write to you of Europe in Belgium. I have just bought a birkine of 1999 to RU since 1 month. I find your car super and I like much the exhaust. can you give me the characteristics of this part. I still have the exhaust of origin with catalytic but it is really not beautiful. still thank you for your council and good sale. About the seats I come to order seats of caterham S3 much more comfortable. bye Peter
  19. Hello kiwibirkin About the doors and roof, as Birkin is a seven like a caterham. You believe that it is possible to assemble the roof and the doors on Birkin. I have a friend who bought R300 caterham S3 frame. it will seek it the next week in the U.K., I will test the parts. Could you say to me which is the value of my car in dollar in your country. It is of 1999 in zetec 2000 with throttle body sump raceline, water rail and rigid bridge borg Warner. But not of roof and not of doors. It is very pleasant to speak with another owner about Birkin. Here in Europe Birkin is rare. My car was imported in the U.K. in 1999 has Silverstone after the lawsuit between caterham and Birkin. I have also Westfield SEIW with a zetec 2000 blue Navy to see the photograph. More the photograph of my head. Good day Peter http://images4.hiboox.com/vignettes/3111/eef64f44c98aafe5e924693edc1f530a.jpg http://images4.hiboox.com/vignettes/0411/b5de5359d5993c1881496eb894ca0e03.jpg
  20. hello This small message to know one can best the members of your forum. I write of Belgium and I have just bought a birkin S3 of 1999 with a zetec 2000 and management throttle body alpha. I will be in the search of new parts and would like to know addresses. Because here in Belgium birkin is not represented. You have chance that birkin exports with the states. I contact also South Africa. I unite a photograph of the car. My birkin does not have a roof and doors. and barrel covers it is old. Still thank you to contact me for information. Peter http://images4.hiboox.com/vignettes/3011/3b18b7b88cbc4b993b8205cc6d0be894.jpg
