My 1999 Zetec started running hot last summer. Not in the red zone but very close. I had replaced the thermostat earlier and was concerned there might be air trapped in the system.
I drained the system and bought an Airlift tool to help in replacing the coolant. The instructions say to bring the vacuum to 24-26 pounds monitor for leaks and open the valve to draw the new coolant into the system. It worked really well in filling the system. However, I soon noticed that
the 26 pounds of vacuum had compressed both the bottom and top tanks of the radiator. I thought maybe the concave top and bottom were like that before I started - maybe up to 1/4" compression but the cracked paint proved that to not be the case.
Still running hot, maybe it's just the sensor.
The radiator has developed a drip-an-hour leak. The leak can be repaired, not sure about repairing the concave tanks.
Anyone know the best source for a new radiator?
I think he means inches (of mercury) of vacuum which is enough to do damage. I'm not surprised an aluminum tank collapsed a bit. I'd never heard of using vacuum to fill a cooling system until now.
Use compressed air to pop them back out a bit, but if it's creased from the vacuum, you'll never get them all the way out.
Using rarified air is a common way to reduce the amount of air in your system when you don't have a vent tank or highest point fill tube.
Does seem a little high though. 15" of vacuum should have been plenty.
Tom
Yes Skip, thanks for the help. It should have read inches. I've attached a picture of the Airlift tool for reference.
Rich,
I like the look of that hose tool to the left of the box. I have several but not one with the reverse hook. Is it a SnapOn item?
Skip,
When I ordered the Airlift from Amazon the Hose Removal Tool popped up as something I might want to order at the same time. It's part # is OTC 4521. If my Google search is correct, Sears sells them too.
Rich
