That does help. Thank you.
Is that the passenger side then?
My calipers are toward the front of the car. That is why I have the clearance issues. I actually had to remove my park brake levers from the Miata calipers just to clear the chassis.
Kind of pricey kit. But if performance is up, and it provides the parking brake I need to be legal, I may just have to try it.
I'll need to do some pondering on parking brake lever location. My elbow takes up the room behind the shifter in my car.
Not sure if you saw where I'm planning on putting mine, but I'm going to mount it vertically on the seat back panel between the two seats. Just need to get some steel strips welded in to hold it.
