xcarguy Posted May 23, 2015 Share Posted May 23, 2015 Hey, guys, I'm gearing up for the rebuild of chassis #85 and am planning a few changes to the old gal. My alternator is curently reversed (see photo and additional photo link below) and sitting up high on the driver's side with the alternator housing perched just above the frame rail. While this setup has NEVER posed a problem, I'd very much like to move the alternator down low (probably to the passenger side) and face the business (pulley) end toward the front of the car. . . . . So, being that a photo is worth a thousand words, if you guys with LS-powered Stalkers sporting alternators in positions other then mine wouldn't mind posting photos of your setup, I'd be very grateful. Thanks!!!! :seeya: Alternator photo file link: http://www471.pair.com/stalkerv/gallery2/main.php?g2_itemId=27136 Link to comment Share on other sites More sharing options...
MightyMike Posted May 24, 2015 Share Posted May 24, 2015 Here's my setup - it is mounted low on the passenger side. The turnbuckle supplied with the kit was too long and I had to install 2" spacers to get the alternator closer to the frame (to allow for tensioning). http://i61.tinypic.com/346qsdu.jpg http://i57.tinypic.com/ambyu.jpg Link to comment Share on other sites More sharing options...
xcarguy Posted May 24, 2015 Author Share Posted May 24, 2015 Mike, Thanks . . . . . But now, might I bug you for a photo of your serpentine belt routing? :cheers: Link to comment Share on other sites More sharing options...
MightyMike Posted May 24, 2015 Share Posted May 24, 2015 The setup is pretty simple - it uses two belts - one for the alternator and the other for the water pump. I purchased the tensioner from Summit or Jegs. Knock on wood, but the setup is working perfectly. http://i62.tinypic.com/1693skj.jpg http://i57.tinypic.com/2yn5jrk.jpg http://i62.tinypic.com/r9gwzn.jpg Link to comment Share on other sites More sharing options...
xcarguy Posted May 24, 2015 Author Share Posted May 24, 2015 Mike, looks like you are runing two belts. Yes? Link to comment Share on other sites More sharing options...
MightyMike Posted May 24, 2015 Share Posted May 24, 2015 Yes - two belts - and suspenders. Link to comment Share on other sites More sharing options...
