I just purchased a 97 with the 1700 super sprint engine. I want to use mobil 1 oil and filter. does any one know what filter # I should use? Thanks
Mine used a Unipart GFE 148, but that was in the UK. Not sure you could get that here...
Hi oldrolex,
I'm not positive about this, but I did a search using a 1980 Ford Fiesta which I believe used a 1600cc Ford Kent engine and came up with the following based on the K&N HP-2009:
Manufacturer Part Number
AC PFL400A
FRAM HP10
FRAM PH3600
FRAM PH5803
MOBIL1 M1209
MOTORCRAFT FL400A
MOTORCRAFT FL400S
PURO L20195
PURO L35098
WIX 51516
WIX 51762
The filters are usually interchangeable by thread size and o-ring dia, the only difference being the size of the filter body. The ones listed above should be about 3'' od. I believe the Ford engine has a 3/4-16 thread, but I don't remember the o-ring dia. Maybe one of the crossflow owners can confirm this.
Hope this helps,
Bruce
