116E engine valve clearance and timing
newtoit
If you have the 116E front cover, this should be of some help:
http://freespace.virgin.net/tommy.sandham/strobe.htm
Otherwise, I think most of the later (i.e. crossflow) front covers have the timing written on the cover.
Valve clearances will depend on a lot of variables (cam, valves, piston to valve clearance, etc) and you should contact your engine builder if you do not know.
