xromad Posted May 18, 2017 Posted May 18, 2017 (edited) This is Classic SuperStalker Chassis #20 Car built in 2004 and titled in the State of Minnesota Trailer built in 2006 and also titled in Minnesota $20,000 for car and trailer together. Engine is a supercharged 3800 from a Pontiac Grand Prix GTP Transmission is WorldClass T5 Differential is 3:42 with GM Torsen Car is very quick and very fun. Has been driven at autocross a couple times but has never seen track use. Comes with a set of 13" racing slicks on steel wheels only used once for autocross. Comes with a custom built drive-on tilting trailer, The trailer no longer has the tool box on the front, it was getting in the way so was removed. I'll post more recent pics of the trailer (without the toolbox) soon. Featues: * Quick Steering Upgrade to newer factory configuration * Cycle wing stays Upgraded to newer stronger style * Upgraded from original 3.4 engine to 3800 Supercharged * Rear brakes are Buick Grand national Aluminum drums. * Have factory disk brake mounting brackets (not installed) * Front brakes upgraded to Wilwood Aluminum Calipers This excellent car has provided my wife and I many years of great fun at various 7s gatherings and trips exploring the countryside. We are sad to see the car go but we will be downsizing the house and will no longer have reasonable storage options. Thanks! Edited August 16, 2017 by xromad
Pcampbell Posted July 12, 2017 Posted July 12, 2017 Still available? How much does the trailer/car combo weigh?
xromad Posted August 16, 2017 Author Posted August 16, 2017 (edited) Hi Sorry, life got very busy and I didn't check the page. I have not weighed them. Back-of-the-napkin guess 1500 Lbs for car, 800 Lbs for trailer, maybe 2300 Lbs for both together. I can try to get a more accurate weight this weekend. Thanks! Edited August 16, 2017 by xromad
B-T Posted August 17, 2017 Posted August 17, 2017 Hi Sorry, life got very busy and I didn't check the page. I have not weighed them. Back-of-the-napkin guess 1500 Lbs for car, 800 Lbs for trailer, maybe 2300 Lbs for both together. I can try to get a more accurate weight this weekend. Thanks! This seems like a really good deal for someone. If you have space for the trailer it sure seems ideal. Nice color scheme on the car also! Good luck with the sale. BT
spitfun Posted August 19, 2017 Posted August 19, 2017 I pm'd you,I wanted to make sure you received it. Thanks Rich
