BlueMax Posted October 5, 2017 Share Posted October 5, 2017 (edited) I had a bad valve stem RH rear leaking so took the tire to have the stem replace on a Avon ZZ1. The tire that had very, very low mileage but may have been dry rotted? In trying to change the valve stem the tire store damage the tire while braking down bead on the inside. Thought about replacing tire back with the Avon"s but also looking at a Michelin Super Pilot III the Toyo Proxes R1R and the Yokohama A032R. Sure would like some input on a good fit for street and autocross aggressive driving. Sorry, tire size now 205/45/16 Thanks Edited October 5, 2017 by BlueMax Link to comment Share on other sites More sharing options...
coffee break Posted October 5, 2017 Share Posted October 5, 2017 Rim size? Link to comment Share on other sites More sharing options...
jimrankin Posted October 6, 2017 Share Posted October 6, 2017 If your going to use it for any kind of event just go with an R comp tire. As you have already seen it's going to rot away before you use it up unless you track it, and then you would want an R comp anyway so see, you can't go wrong. Link to comment Share on other sites More sharing options...
glenntwincam Posted October 6, 2017 Share Posted October 6, 2017 sounds like you need a new tire store Link to comment Share on other sites More sharing options...
BlueMax Posted January 4, 2018 Author Share Posted January 4, 2018 Well, decided to try out the Bridgestone Potenza RE71R . My sales rep at the Tire Rack said that these were a awesome street track tire.. Link to comment Share on other sites More sharing options...
