Hi , as anyboody used a Mazda Miata for a doner car to build locost/tiger etcs. Im interested in any info ,my choice of a Miata, is because they are more availible in the states than the Fords for parts ,I know one person downunder has done this using the subframes ,Engine etc,just wondering if anyone here has done this & could give some info ,thanks Larry
Westfield makes a specific model that uses everything from a donor Miata right down to the gauges. It's worth seeing what they did.
dave
My Westfield used a Miata donor car. Engine, trans, diff, halfshafts, wheels, brakes, wiring harness, instrument cluster (though I did my own cluster with all VDO because the steering wheel hid too much), ECU, and a lot of little things like the air cleaner, etc. The driveshaft was custom, as the car is shorter and the engine is entirely behind the front "axle".
What im looking for are plans with sizes & specs.etc Distance from front sub.frame to rear sub. frame etc if anyone can help, thanks in advance, Larry
No Mazda chassis or subframes or A-arms used in the Westfield. Try a Catfish or Exocet. I *think* they use the Miata subframes.
I also built the Westfield kit using an NA I had been driving for years. As Dan said, the kit comes with a frame and a-arms. It does use the miata's hubs. I wrote up some of my experiences here, and I'd be happy to answer any questions you have.
