Toyo R888 tire pressure for motorsports
Andy69
The general consensus seems to be 18 PSI for these tires as a starting point. I had it out at the track yesterday and didn't get anywhere near the diamonds, of course I wasn't trying to find the limit as I had my 14 year old with me.
If anyone uses these tires for autocross, what pressures do you run? It may very well be 18 psi and I just need to be more aggressive :-)
I run the R888R in 15" rims. My cold pressure setting is 10 front 12 rear. I am not truly comfortable running that low a tire pressure but it's what it likes.
Graham
Graham
wow that's super low.
but if that's what enables to you use all the tire surface, it is what it is
If I go below 18 psi, the rears wear only on the outside and the outer edges of the rear tires get chewed up on the track. I started at 20, and 18 seems to be the lowest that works for me on 15 inch rims. I have a Birkin without IRS. The tires get plenty of heat into them.
