TPS for Jenvey ITBs on FI Zetec
fatallightning
I think my tps is on the fritz, and looking at what Jenvey sells for the ITBs, I ordered a D drive contactless unit. I went to clean the existing one just to see if it would clear up some of the running issues, and lo and behold, it's a Lucas part with a shaft drive. Evidently shared with classic Rovers, and NLA, and quite $$ from breakers or NOS. Looks like many Rover owners are using machined adapters to use the more common D drive Colvern type units, so it's kind of odd my car seems to be the reverse. There does seem to be a machined alloy plate, as I'd assume the TPS normally threads straight on. I'll unbolt it to get a better look at it, just curious if anyone else has a similar setup.
