Pokey Posted September 27, 2020 Posted September 27, 2020 If anyone is considering the Schroth harness from Catherham (https://caterhamparts.co.uk/seatbelt...roth&results=5), be aware that the hardware provided won't allow the brackets to swivel. After ordering a variety of bolts, swivel bushings (top hats) and washers from Schroth, I finally figured out that what is needed is the SG11 shoulder bolt for the B24 bracket and the S3 wavy washer. Four each of the B24 and S3, plus the four spacers that are included with the harness, are needed for the belt and shoulder straps. For the crutch straps I used the supplied bolt, 7/16" oversize washers for spacing, and a nyloc nut. 1
UglyFast Posted November 10, 2025 Posted November 10, 2025 On 9/26/2020 at 9:17 PM, Pokey said: If anyone is considering the Schroth harness from Catherham (https://caterhamparts.co.uk/seatbelt...roth&results=5), be aware that the hardware provided won't allow the brackets to swivel. After ordering a variety of bolts, swivel bushings (top hats) and washers from Schroth, I finally figured out that what is needed is the SG11 shoulder bolt for the B24 bracket and the S3 wavy washer. Four each of the B24 and S3, plus the four spacers that are included with the harness, are needed for the belt and shoulder straps. For the crutch straps I used the supplied bolt, 7/16" oversize washers for spacing, and a nyloc nut. Going through this right now. Will have some photos in a day or two and happy to hear input about my setup (and the physics of safety) bc it seemed a bit too easy. 1
