I have LEDs for my rear running/brake and turn signals)
I have a ballast resistors wired into the flasher circuits (to stop hyper Flash) do I need one for the rear lights?
As I seem to be having some issues, the turn signal buzzer is sounding, not full but like it is being fed a weak voltage and both the turn signal and high beam indicator lights are on, dim but on.
The left turn signal is not working with the headlights on but the right seems to be flashing.
If I switch off the headlights everything seems OK lights go out buzzer stops this happened at the end of a 45 minute drive this evening.
Edited by Brightonuk
