Miata Oil Pan Baffle Query.
DanM
I'm in the process of assembling my NA MX5 1.6 and wondering if I should install an oil pan baffle.  The car is going to be primarily autocross and street.
Will I benefit from having one, considering the usage?  Now is the time to do it while the engine is apart.
Thanks Dan
Of course, what keeps oil from moving up usually keeps it from returning to the pan. I could see the benefit of a filler plate across the rear to keep it from moving up the back of the engine during accel, or a crank scrapper along one side that shears oil from the crank, or a mesh screen windage tray, or trap doors around the sump similar to what you might see in a fuel tank, but I don't see any benefit to adding this plate, imho. The original piece is better if this is intended as a replacement for that.
