The remaining bits as pictured.  Also have new front upper ball joints and poly LS V8 motor mounts.  Empty rear axle housing also available, from local guy I sold the axles to.
  • 4 weeks later...
It is unlikely as they are not in this post, but do you still have the control arms?
If not, do you know what parts numbers you previously had?
I am a relatively new Stalker owner (legacy chassis) and have a damaged lower front and am not sure where to go/what to do for a replacement.
Have you tried reaching out to Scott at Stalker?  I sense if anyone knows he does.  He can be a little slow to reply, but will get back to you.
If one arm is bent, you can have a fab shop use the good side to make a mirrored arm. They may be able to rebuild the bent one.
I emailed and talked to him over a month ago and he said he would send me a quote—nothing yet.  Last I checked, the Stalkercars website has been suspended.
I might have to go that route.  I was leading a local time trial series and wanted to get back on track as soon as soon as possible, but it is already too late.
The actual mount ripped from the frame taking a piece of the frame with it, so that needs attention too—maybe I need to start my own thread... .
