SOLEX Carb Q
SOLEX 34 DGEC.
Does anyone know if these Weber clones use Weber jets, tubes, etc?
Not a Chinese copy. These are legit carbs with a complicated history.
Edited by IamScotticus
The jets are not the same.
When jetting from scratch, you'll  need a good supply of brass parts ($$$) and a A/F ratio gauge.  It can be done (I have done quite a few) but it isn't cheap!  It is ALWAYS easier and cheaper to go with a carb with a known baseline for your engine.  Then maybe just a few mains/air correctors to dial it in perfectly.
I set up Dellorto DVLAs on a Renault crossflow.   I ended up with about a $800 of brass.  Run beautifully now though.
True that.
The best way I know so far is to bypass all the experimentation and get a prepared carb from a FF tuner like Ivey.  Also, most of the webber books I own have lists of standard jettings for, say the Cirtiba GT, etc.  Good enough to get me running.
The SOLEX was a gift (Thank you 👏🫵)
Ive already found out the expensive part of buying jets.
Its in the shipping costs for every single time I have to buy another set until I settle on the set that works.  Better to settle on a single carb base model, like a Weber or Delorto, then buy a full range of jets, tubes, gasket and rebuild kits.
That would probably cost as much as a whole carb but Id have enough to play with without going back and forth in the mail.
Were you comparing to jets you had on-hand or an original carb? Was it the thread? Numbering? Completely different design? Just curious.
Honestly, I haven't opened it up to find out.  Im relying on the collective wisdom here to save some time.  My only other Webers are DCOE and a 32DFM.
Carbs can be a complex subject
A snippet fron the aforementioned article:
"Consumers should be aware that what this company is doing is importing a Solex designed carburetor from South America – branding it a Weber – and calling it a “Genuine” Weber. They reason that if Magneti Marelli owns the Solex factory then it can legally be called a “genuine” Weber...Now this company has taken it a step further (as of the Summer of 2011) and is now supplying the 32/36 DGV series and the 38 DGS series carburetors and branding them as Weber's just as they did with the Solex Carb's from South America."
"That company", a prior N American distributor, is no longer importing these, I understand.
The article, the best I've found so far, doesn't mention parts interchangeably or performance.  The issue is branding.
I don't have any reason to doubt that my carb will work as a carb should,  but if I need tubes and jets, will Weber parts interchange?
Or is my carb bespoke?
Of course the answer is put it on and find out.  I'm several months away from that.
I misread your initial question. I thought you were asking if the China knock offs have the same jets as an actual solex.
 Share
