Rear light wiring identification
das76
There are 4 wires for the rear lights:
Black (ground)
Red/White
Green/Purple
Green/White
I'm assuming someone here know which one is for each function?
Also, what gauge wire is used ?
I'm working on a neat project that you guys might find interesting.......... stay tuned.
Edited by das76
I went through this with my k series.
Black (ground)
Red/White
Green/Purple
Green/White
Wiring for most British cars has been pretty standardized over the years. I've used old MG and AH wiring harnesses to add or repair circuits to existing harnesses. Here's a link to typical British wiring color codes: https://www.autosparks.co.uk/bscc
I've also found this place to be a good resource for electrical/wiring parts for British cars: https://www.britishwiring.com/default.asp
Black (ground)
Red/White - Tail lights (can be just red with no white tracer)
Green/Purple - Stop lights
Green/White - RH turn signal (Green/Red - LH turn signal)
