Cueball1 Posted April 24, 2024 Posted April 24, 2024 George Hillards old Birkin has a Girling .75 master cylinder leaking. I've disassembled it and the bore looks clear and unmarked. I am planning to rebuild it. The question is... This car has 3 of these same units. Front brakes, rear brakes and clutch. The car has only 8k miles but is right at 20 years old. Should I go ahead and rebuild the other two that are still good, figuring it was maybe age that caused the failure? Or would I be making unnecessary work for myself?
IamScotticus Posted April 26, 2024 Posted April 26, 2024 (edited) If the master is a TRW PMC146 (GMC226TRW) buy new and replace Edited April 26, 2024 by IamScotticus
Cueball1 Posted April 26, 2024 Author Posted April 26, 2024 They are genuine Girling remote reservior units. The girling part number looks to be 64067620. Took one off and disassembled. Bore and piston looked good. I think it's just deterioration of the 20 year old rubber gaskets. Have the parts to rebuild in hand. Fingers crossed it works! Same unit as this... https://www.merlinmotorsport.co.uk/p/girling-master-cylinder-remote-3-4-inch-bore-64067620-gmc-12-r
jbcollier Posted April 27, 2024 Posted April 27, 2024 IF: - the bore is clean, smooth, free of any signs of scoring, and; - the piston is perfect, no marks whatsoever, and no measurable out-of-round; then, by all means, rebuild the cylinders. If the rubbers in one went, then all three are due. Any signs of wear on the bores or pistons, replace them instead.
