The plastic shaft of the 24 tooth speedo driven gear on my '04 Roadsport SV with T-9 gearbox has broken, which allows gear oil to leak out. I am replacing it and have it disassembled, only to find the new gear I have is 22 teeth, not 24. Does anyone have one or know where one might find this part? The Ford part # is 60110586 I believe.    Any help or leads are  very much appreciated!
Mark Bondurant
Franklin, OH
Mike
Thanks very much! I have some time because I’m working on some other repairs as well, so I will follow all your suggestions. Hopefully I will be able to find something on this continent.  I very much appreciate your prompt response!
Cheers
Mark
Thanks all, I was able to get a 24T gear from Transmission Parts Online, an EBay store in the UK, which arrived in just 3 days. Very prompt but the metal tip of the shaft was quite rough. I was able to find a snug drill bit to put into the gear end, and was able to chuck it up into the drill press. Using a medium slow speed I started with 400 wet/dry sandpaper (dry) and progressed through 2000, which smoothed it and put a polish on it. Reinstalled it and got the sensor connected. Will test it when I have the driver’s seat back together and in the car. Had 3 failed welds in the seat frame which I will discuss in a separate post.
Cheers!
Mark
