Grady Posted January 12 Author Posted January 12 (edited) I have the CF on order so I went ahead and utilized my masters I have in CAD design this weekend. This way I can get my layout figured out prior to doing the cutting on the CF sheet. I found some different switches for the lights that will simplify the layout. In removing all the breakers this is going to make the right side empty. This will be a good place to mount the holder for the Garmin Catalyst. Tried to take the picture from where my eyes will be. Edited January 12 by Grady
Grady Posted January 12 Author Posted January 12 1 hour ago, bball7754 said: CAD = Cardboard Aided Design? 😊😊 You know. It! 1
Grady Posted February 3 Author Posted February 3 Got the rough cut done and the attachment screws drilled. Now a lot of sanding to get a good fit. 1
Grady Posted March 24 Author Posted March 24 Have the mounting done of the ADU5. Basic power and ground hooked up. Running wires for oil pressure, coolant temp. Need to get all the sensors installed and wired in. But working on the basic programming/layout of the display. Here is what I have so far. 1
nc7s4 Posted March 24 Posted March 24 Love it. Still space for the fire bottle pull handle right in the middle. Are you planning to race it?
Grady Posted March 24 Author Posted March 24 13 hours ago, nc7s4 said: Love it. Still space for the fire bottle pull handle right in the middle. Are you planning to race it? No racing for me. I will track it. Thinking this would be a good one to do some Autocross. Never done that before.
Grady Posted April 4 Author Posted April 4 (edited) More progress with the keyless system. Have it wired in and working. Removed the breakers and installed 3 fuse blocks. 1 for battery, 1 for accessory and 1 for ignition. The battery shutoff is now a real shutoff and kills power to everything. As soon as the key moves it wakes up and activates the system to go into Acc mode. Now just need to wire in the brake light and get the sensors working for the ECU master so I can do an engine start. Edited April 19 by Grady
Grady Posted April 11 Author Posted April 11 Ok got everything working. Seats are at the interior shop so can not test the MPH reading yet. Calibrated the Fuel gauge and temp sensor. Wired in Alt out, L and R turn signals. Programmed oil pressure warnings. Still need to wire in oil temp later.
Grady Posted July 15 Author Posted July 15 Some more progress. Since the stock rear diff was spitting teeth I have replace the LSD with an MFactory one. The seats and center console are done. I have covered the back sides in carpet. The floor I have done in truck bed coating. Placed the seats and seatbelts in to see the look. I am happy with the colors I have picked out. Need to get the center cover installed, seats permanently installed and rear end alignment. Then it will be ready to drive agin. 2 1
nc7s4 Posted July 15 Posted July 15 Do you have an r160? How did it break? I broke the pinion gear on mine so replaced with an r180
Grady Posted July 15 Author Posted July 15 Yes it is a R160. Searching around this looks like a common failure of this diff.
Grady Posted July 17 Author Posted July 17 Now I just need to install a shift boot. Going to make the surround out of the left over CF from the dash.
