I have the CF on order so I went ahead and utilized my masters I have in CAD design this weekend. This way I can get my layout figured out prior to doing the cutting on the CF sheet. I found some different switches for the lights that will simplify the layout. In removing all the breakers this is going to make the right side empty. This will be a good place to mount the holder for the Garmin Catalyst. Tried to take the picture from where my eyes will be.
Edited by Grady
1 hour ago, bball7754 said:
CAD = Cardboard Aided Design? 😊😊
You know. It!
  • Haha 1
Got the rough cut done and the attachment screws drilled. Now a lot of sanding to get a good fit.
Have the mounting done of the ADU5. Basic power and ground hooked up. Running wires for oil pressure, coolant temp. Need to get all the sensors installed and wired in. But working on the basic programming/layout of the display. Here is what I have so far.
Love it.  Still space for the fire bottle pull handle right in the middle.  Are you planning to race it?
No racing for me. I will track it. Thinking this would be a good one to do some Autocross. Never done that before.
