pethier Posted September 12, 2024 Posted September 12, 2024 (edited) I didn't remember to twist the wire for this shot: The wire ends in a terminal ring seen here edge-on. The wire was rolled up and cable-tied to what appears to be the factory Caterham harness. Since the wire is black, I checked it with an ohmmeter to ground and found the resistance is 0.3 ohms. Is it safe to assume this is meant to be a ground wire for some component that's doing a reasonable job of grounding itself? Is it likely that it is supposed to be grounded by that fastener there on the bottom of the fuse block? I did not see any other obvious existing places for it to live. Edited September 12, 2024 by pethier typo correct
MV8 Posted September 13, 2024 Posted September 13, 2024 (edited) I would not assume. It is true that black was usually just for ground around 1991. It may be a mistake in the harness as an extra ground or something else. If it stays grounded when the key is in all other positions, it is probably a ground. If everything works as it should, there is no harm in cutting it out. I'd leave it, tape the end and stow. Edited September 13, 2024 by MV8
pethier Posted September 13, 2024 Author Posted September 13, 2024 I put a voltmeter on the ring and ran every system on the car. Gaining confidence in not seeing significant voltages, I bolted it to the firewall and drove the car to a Minnesota Triumphs meeting.
