For Sale;  Early Seven TR10 Rear Axle Housing and 4.55:1 Differential.
                 Originally from a 1960 Seven Series 2 America.  $750/OBO.
                Early Reinforced Toyota Corolla Rear Axle suitable for use in a Seven S2 or S3.
                Reinforced Axle Housing.  $1750/OBO.
Doug Brown
Alton Bay, NH
3D7B89D4-9ABE-46ED-AAB7-0CBCAC5CB9B3_1_105_c.thumb.jpeg.17300fc3cd6e260d04bc5e464bc8cb81.jpeg
F4DFFA62-CC73-4EF0-A113-EE4F5AB96F72_1_105_c.thumb.jpeg.33c0646ea2a5d6f6a3d8ef67399e8fa2.jpeg
D6F7E060-A04C-4C63-8418-E55E7C14403C_1_105_c.thumb.jpeg.be3960d1934d18f7619b2429b07d5e0e.jpeg              8214989D-DE93-4DDB-9F5B-E1715F725CC8_1_105_c.thumb.jpeg.517b49db7793dd542b6e9aaecbf84f68.jpeg99E0DE63-1A22-45A2-A708-50939D0D650A_1_105_c.thumb.jpeg.5450d11ca19a4dc4b82b71c2440ef134.jpeg3C2113AF-BF75-488D-AF57-0BF8F3690C68_1_105_c.thumb.jpeg.e2c66b826ff21c5699d6de6c6331ea05.jpeg
Also, for the Reinforced Toyota Corolla Axle the rear end ratio is 4.2/1.
The width of the axle from drum face drum face is 51".
It is a great substitute for the fragile TR10 rear axles.
110mm or 114.5?  The axle in my Rotus is from the Celica-Supra and definitely 114.5mm.  I'd be surprised if Toyota was dabbling in multiple wheel patterns.  The good news is 114.5 gives you plentiful options.
My axle is also from Chris Custer at Rotus!
It was from a Toyota Corolla and depending upon the specific model could be a 110 or 114.5 PCD.
My initial measurement was 110mm.
However, I will double check measurement.
  • Confused 1
  • 4 months later...
