I need to change the dip switch settings on my brand new build with Smiths tach. Can anybody walk my thru this?0
WIth a four cylinder and a distributor it is sw 1, 2, and 8 on. With coil packs, it is 1, 3, and 8 on. 8 is always on.
There is a grommet/plug backing that is pulled out to access the switches.
Yes. Get under the edge with a butter knife, then lift the knife away from the tach.
Edited by MV8
The tach body is threaded. The thin, outer plastic ring is a long nut.
Should be able to unplug the wiring connector, unthread the ring from the tach body, and pull it straight out of the panel. No tools required except may when trying to squeeze the black clip on the wiring connector to release it.
Edited by MV8
Thanks! That is the info I needed. I thought it was screwed in, but I needed to make sure I didn’t break anything. I will need to remove the steering wheel.
  • 1 year later...
That's different.
I'm really used to the metal bridge held by a couple of nuts on studs attached to the back of an instrument case.
