Dan Pantages Posted August 13, 2025 Posted August 13, 2025 Hi all. I have a new set of Spax shocks for the front of my 7S4. my problem is not finding a way to compress the coils to get the old shocks off and then of course getting the new shocks on. I have a set of spring compressors but they are way too big. I have not been able to find any that will fit. Any ideas preferably with pictures.
MV8 Posted August 13, 2025 Posted August 13, 2025 I have several types. I guess what you have is an internal compressor? This kind is iffy when there isn't much room between coils near the ends: https://www.ebay.com/itm/286552241360?_skw=coil+spring+compressor&itmmeta=01K2JS4MH497HXE46N6GM8YWRR&hash=item42b7d834d0:g:UwsAAeSwmd5oY5Ko&itmprp=enc%3AAQAKAAAA8FkggFvd1GGDu0w3yXCmi1ckGI7Uy%2FlRNE9OS5qoDHfEbXBaEVpesOxaQE6QWZuKFBRpaUwubr9UjrzirX2VQE6hwESMx1rDPXb34AWjZxldalL5XGQM8VgdQBH4ZV9tCey%2FBJP3AsbZ0BMlY%2FW5zaGDhj7CaJuugMr3sINHZ1CpkwqAMIXlusmKqF0VdsQkNWIbLLnXalQuw%2BHQ3e2syep%2BxK8Q3yYN%2BEvgA439lzV3FbiYPIf2EgGZUcn7RUWKv0e%2BTKiuUGjCFbjcoGSIMIWzfJSJ%2FF8tSFWYTBgKSWDiBv9zuSmO1tfgmnZnjHsJRg%3D%3D|tkp%3ABFBMgMqS2ZRm This one will probably work: https://www.ebay.com/itm/404835949894?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D290432%2C290494%26meid%3D6da5a0a5b5114d8898c030578f49103e%26pid%3D101875%26rk%3D3%26rkt%3D4%26sd%3D267343517564%26itm%3D404835949894%26pmt%3D1%26noa%3D0%26pg%3D2332490%26algv%3DSimVIDwebV4WithCtxRankerV1ECPM&_trksid=p2332490.c101875.m1851&itmprp=cksum%3A4048359498946da5a0a5b5114d8898c030578f49103e|enc%3AAQAKAAABAHpsrQN%2BfAdDZYpPJGYWcJeM%2B7kOu0qCwhwpE0jI5WLZbLunKqjjv17aqA5FlcDVyp%2B8KZIzRyS8ZZgusw%2FXh%2FpnKleLAdyjIU9BjgRe8KMsdyQKAaavH3NKOKo2eLChYZfmzw7q%2FEyhNlKAcEKyl8ADGBjNFfXoLXc0ZcrwGtKZ0yf%2B2NkmjfXyHUoc%2BFAlSPZz28aHAYsh2myF5gM1B37eke33OQ7bRRPHbjtc6s0W4eKigjQWOVjlZhy7HvJ9qa79O%2FF5u4NBytkZRUwZWTTkOVVKXvrMyPST12WFMzXVaeBN37%2FGhTjLFs%2BimHjOunQwn3aM5YObFatYGppewSE%3D|ampid%3APL_CLK|clp%3A2332490&itmmeta=01K2JS91S3VQ0799PHZVVZ0P11 These are for larger springs and work well but you probably would not be able to engage more than one tab: https://www.ebay.com/itm/133734297396?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D290432%2C290494%26meid%3D5ec38632b1ea4abcb9a66eb9ed86f907%26pid%3D101875%26rk%3D3%26rkt%3D4%26sd%3D404835949894%26itm%3D133734297396%26pmt%3D1%26noa%3D0%26pg%3D2332490%26algv%3DSimVIDwebV4WithCtxRankerV1ECPM%26brand%3DUnbranded&_trksid=p2332490.c101875.m1851&itmprp=cksum%3A1337342973965ec38632b1ea4abcb9a66eb9ed86f907|enc%3AAQAKAAABEHpsrQN%2BfAdDZYpPJGYWcJeM%2B7kOu0qCwhwpE0jI5WLZbLunKqjjv17aqA5FlcDVyvHawCiovueK%2BZKmPUwri9IvWpVpIoHS8gokfCn4EpU%2B1XA%2FGBvq%2Bsr0cWoDsXJGW%2FliWKN0m1TDh%2BGRsZ1t51IrlH6EABue2JZMHcdrcqIHYXBMYjbGUbS8xb9R2H9qJT8tlpWNyePJxMW5A3JJ83vtHotct%2BXZpw6UhNQf%2BlIOg%2F6rSrsbNW4fRVQmO16cuLGy7R0Tm%2Fe0Hyf7em6gsEidPW2XlINjpzJnIOPd3eov0zBNGLg4AmieJbQ%2F9odpM0F2xC2EeNiHHp28woAXHO%2Fv6nC4HBFIzSY7xQdgFvej|ampid%3APL_CLK|clp%3A2332490&itmmeta=01K2JS9YNE11M97KQS2MAN733D
Dan Pantages Posted August 13, 2025 Author Posted August 13, 2025 The spring purchase is threaded thus adjustable to raise the spring tension or lower it. You can't take them off that way.
Dan Pantages Posted August 15, 2025 Author Posted August 15, 2025 (edited) OK, job done. A friend has a vertical hydraulic press. A clamp on one end and the press the other end. Edited August 15, 2025 by Dan Pantages Wrong word used.
