This car is making me feel stupid.
The brakes, turn signals, and hazards don’t work.  They worked before so I think maybe there is a commonality to the failure somewhere.  Bad ground perhaps.
But I was going to check the brake light switch and there isn’t one?  At least, none I can find anywhere in the vicinity of the brake pedal.
Also, there is a switch of some kind on the accelerator that is pressed once the pedal comes fully back but it doesn’t do that, just hangs there and doesn’t press the switch.
1992 Supersport K-series
pic:
Edited by Andy69
Hydraulic brake light switch like the old VW Bugs and outside the (pedal) box.
I think the throttle light switch is some sort of "gas-lighting"?:classic_blink:
Edited by MV8
Look on the master cylinder for a button looking thing with 2 wires ,that will be the brake light switch ,if it has a hyd switch
Yeah ok, I saw that and I thought maybe that was what it was.  Does it need to be primed or the res filled to a certain point?
Wait a sec, isn’t the one on the MC the brake failure switch?  Looking up the Lucas pressure switch for the brake lights ( SPB401?  ), I see it looks like a pressure switch on the brake distribution block right below the MC.
Check across the terminals with a test light probe , one side will always be hot , press on the peddle the other terminal  should lite up .
If not , switch is bad or no fluid . The brake lights normally run through the turn signals switch
That might be a BRAKE FAILURE switch , not stop lite switch
Yes on both counts.........
Broken wires in the left taillight were the cause.
Work great now.  On to the hazards/indicators
