Bill Posted October 30, 2025 Posted October 30, 2025 What mechanical fuel pump is recommended for a 1340 Cosworth Ford engine with webers?
MV8 Posted October 30, 2025 Posted October 30, 2025 I'd recommend an electric. https://www.burtonpower.com/mechanical-fuel-pump-ford-x-flow-ohv-kent-ffp445.html
IamScotticus Posted November 1, 2025 Posted November 1, 2025 (edited) From Pegasus https://www.pegasusautoracing.com/productdetails.asp?RecID=31616 Use a spacer block with these pumps https://www.pegasusautoracing.com/productdetails.asp?RecID=3583 These mechanical pumps are known to have adequate flow at the recommended low pressure of 3-4 psi. The Formula Ford racers run these to feed 32/36 DGVs without pressure regulation. But I think the DCOEs are different, perhaps more pressure sensitive. I would recommend a pressure regulator for DCOEs, even from a mechanical. I could be wrong. But certainly regulate any electric pump. Edited November 3, 2025 by IamScotticus
jbcollier Posted November 1, 2025 Posted November 1, 2025 Fit the correct pump and you do not need a pressure regulator.
