I have a trackdays coming, and my end links have a lot of play. Caterham has them in stock, but I won't be able to have them in time. Anybody know if they are from another model / application? I see online lots of similar end-links, anybody knows if they could be sourced at least similar in this side of the pond?
Thanks!!
I don't know of any application that would swap in directly, but you might be able to fabricate a setup that would duplicate the dimensions of the Caterham end links.
Check out the 'Ball Joint Linkages' section of this link at McMaster-Carr: https://www.mcmaster.com/products/rod-end-connectors/rod-ends-2~/
They also have connecting rods to work with male or female threads: https://www.mcmaster.com/products/rod-end-connectors/connecting-rods-1~/
Edited by 11Budlite
