I'm replacing the seals and gaskets on my Type 9 and I have mixed the 3/4 blocker bars with the 5th gear blocker bars.  I don't see a reference in the Ford manual or the Haynes manuals posted in the library. Does anyone have the spec/measurements on those?  It looks like the length (19.6mm) and width (5.5mm) are the same but the height when viewed from the side is different.  Mine measure 4.88mm and 4.16mm.
I have a T9 sitting here. Is this something that can be checked in situ?  I'm not wanting to pull it apart.
Put up some pictures
Edited by IamScotticus
The measurements are 5.5mm wide (picture 5) by 19.6mm long (pic 2) all are those dimensions.  The height is where the difference is.  One is 4.88 mm high and the other is 4.16 mm high.
