I have what looks to be a triangular mount for a differential.  I'm not sure what it's called but it is straight; no kinks or bends.
$100 .  Shipping will be from the Atlanta area.
Contact - GJZ30075 -at- gmail.com
Edited by gjz30075
Its called an A Frame.  Its part of the rear suspension for a Caterham.
It may be straight but does it have any dings or divots in the powder coat that would be a harbinger of possible damage?
Then to ask the second obvious question - which model Caterham is it for?  An S3 or an SV?  Then which S3 chassis - imperial or metric?
From the design at the top of the A, I suspect it is an S3 imperial but a prospective purchaser will need to validate that with you.
All fair questions.   I'm an Elan guy and my knowledge re: Caterhams and 7s is limited.    I'm selling this as part of an estate of a deceased friend who
was a Europa owner and possibly a Caterham owner in the distant past.
It's painted and has numerous scratches but no dings or dents.   It measures 36 1/8" across the bottom of the 'A', end to end.  From the center of the
center bush (no bush installed) to the bottom of the 'A' tube, the measurement is 10 3/4"
Hope this helps someone.
Thanks.
  • Thanks 2
  • 2 months later...
  • gjz30075 changed the title to FS: Differential mount, best offer. **Sold**
