Wanted to share, the team at Caerbont Automotive Instruments, manufacture of the Smiths line of gauges, has put together a set of gauges for my 620S.  I wanted an instrument cluster that offered a better aesthetic to the light leather interior I spec'd.
On their website I came across their Motorsports line with while gauge faces and a modern lettering I thought would fit the bill.  After a bit of back and forth I was able to commission a set of gauges to match.  for compatibility reasons, the new set would need a bit of engineering to be plug and play.
I just received the update that they are ready to manufacture them and sent over the mock up.
Im quite pleased with the results and am excited to recive the gauges.
Robert
Edited by Exarkun1178
  • Like 5
Now the real question.... is the gas gauge accurate?!
Also, wow, those look stellar. Is the trim polished aluminum or something else?
Anodized aluminum is the spec. I suspect the mock up will not capture what it will look like in person.
TIL you can just call them up and have them make custom setup for you! Are they going to send to the factory for installation directly? The spec on your build from the other thread goes crazy, this is another great touch!
The timing wount work to send to factory.
i did try that with the moto-lita but caterham folks said no. I did ask about why m, this passed weekend, and was told they have not done any testing with the the spec’s wheel. So I took it as a liability concern
as to the gauges, the car is expected to be finished up this week. The gauges won’t be ready maybe for 2 more weeks.
the tech building my car did share how easy it will be to swap.   So at this time, I’m not worried
  • Thanks 2
