a.moore Posted Friday at 08:15 PM Posted Friday at 08:15 PM I'm dangerously assuming that since most of the car was sourced from someone else's parts bin so were the suspension bushings. Is there a list of the original application for each rubber bushing?
IamScotticus Posted Friday at 09:56 PM Posted Friday at 09:56 PM I copy info I find on the net, use at your own risk. Some of this may be incorrect. But I try. I have not seen a complete list of the donor vehicles. BUSHES GENERAL ********************** Y16 (tapered)Front Suspension Link Bush AUSTIN FROGEYE SPRITE MG MIDGET & 3000 equiv: MRM220 03471R MGB AH SPRITE MK3 AH 3000 MK3 AH SPRITE MK4 CROSS REF: 2A4027 2A4163 330-520 88G274 Rover 88G274 Length: 17mm Wide end diameter: 29mm Narrow end diameter: 23mm Centre hole diameter: 12mm Fitment to wishbones and anti roll bar (8 per car) MOSS pn 330-520 *********************** Y9 (Tapered)Control/Trailing Arm Bush EAN# 5016593126077 Cross Ref: Rover 8G621 281-405 MG Midget 1/64-12/79 MG MGC/GT 1/67-9/69 MGB all TAXI FX4 1/59-12/89 TAXI FX4R 1/82-12/85 ROVER A60 CAMBRIDGE 1/62-10/69 AUSTIN HEALEY BN 1&2 53-56 BN 4&6 SPRITE MK3 3/64-10/66 SPRITE MK4 3/66-10/71 3000 MK3 3/64-10/71 Length: 23mm Wide end diameter: 29mm Narrow end diameter: 23mm Centre hole diameter: 12mm Fitment to wishbones and anti roll bar (8 per car) MOSS pn 282-305 ************************* 636 (B636/2) Length : 3.5mm (1 3/8") Total diameter : 2.7mm (1 1/16") Opening diameter : 1.3mm (1/2") ************************** B636/2 Short (S636/2A) Internal diameter: 13mm External diameter: 27mm Length: 26mm ********************* B6362 Short (B*636/2A) Internal diameter: 13mm External diameter: 27mm Length: 26mm *same as S636/2A with a "B". Typo?) ************************** RB636/2 Wishbone, A frame, Radius arm Internal diameter: 12mm External diameter: 27mm Length: 34mm **************************** BP636/2 Top Link Peened Length : 3.5mm (1 3/8") Total diameter : 2.9mm (1 1/8") Opening diameter : 1.3mm (1/2") ***************************** E2030 Radius Arm Small Length: 31mm Centre hole diameter: 9mm Outer diameter: 19mm ***************************** E2030 Short (S2030A) Length: 26mm Centre hole diameter: 10mm Outer diameter: 19mm ***************************** Bush Eyelet Front (E4-B46-608C) 35MM ***************************** Steering Column Bush (B8466) ***************************** Caterham suspension Bush Kit Live Axle (BU03K) ****************************
EdWills Posted Saturday at 11:10 PM Posted Saturday at 11:10 PM @IamScotticus has supplied a very comprehensive list of types and sizes for a Caterham and Lotus Seven. The original bushes sourced by Lotus were produced by a company called Metalastik (sometimes spelled Metalastic). As noted on the web it is: "A famous historical British brand of rubber-to-metal bonded components, including flexible bearings and bushings founded in Leicester in 1937 by engineer Mac Goldsmith. The brand is now owned by Trelleborg, and distributed in the U.K. by Robush" A number of road and racing car manufacturers relied on Metalastik rubber and metal bushings for suspension, engine mounts, gearbox mounts etc. Lotus as well as many other car manufacturers made use of them as shown on Scott's post. Caterham still shows a few for sale on their web site, but check to see if they are metric, before ordering for an early Caterham (which may still have used Imperial sizes), or a Lotus Seven (which definitely did use Imperial). W 1 2
IamScotticus Posted Sunday at 01:52 AM Posted Sunday at 01:52 AM https://www.robush.com/products/bush/
