Ian7 Posted December 29, 2007 Posted December 29, 2007 For purposes of verifying / redesigning fuel system, does anyone have measured or manufacturers data for fuel flow rate in a dual-weber 1600cc Kent (say 125hp) at max load? In pounds per hour or gallons per hour, either way thanks
slngsht Posted December 29, 2007 Posted December 29, 2007 for any given engine, flow rate in lb/hr = peak power (hp) * BSFC (brake specific fuel consumption). BSFC is roughly about .5 to .55. So, if hp=200, lb/hr is roughly about 100. Hope this helps.
