southwind25 Posted January 8, 2008 Posted January 8, 2008 Needed: for a ford 1600 does anyone have a spare valve adjusting screw, and possible rocker #1. i was told the screw cracked in the process of it's adjustment. I am not sure why, it might be a simple fix, but i also might need the rocker if it's x-threaded-galled-or whatever. I want to fix this when we recieve the car. anyone have a spare? Thanks RK
fnmag58 Posted January 11, 2008 Posted January 11, 2008 RK, I have an entire rocker assembly--all the rockers, adjusters, spring spacers, etc. Came from an engine that I am rebuilding and replacing with the HP aluminum rocker set-up. Send me a follow-up if you're interested.
southwind25 Posted January 12, 2008 Author Posted January 12, 2008 sent PM yes i am interested.. the adjuster screws seem to be .4125 across the thread diameter,,if that makes a diffrence?
Ian7 Posted January 12, 2008 Posted January 12, 2008 good source for Kent parts is this racers forum: http://www.apexspeed.com/forums/
