I purchased this out Ebay for $200.00 + shipping. Now I need to learn to use it!
http://www.usa7s.com/aspnetforum/upload/1480159571_P1010672.JPG
http://www.usa7s.com/aspnetforum/upload/678291452_P1010670.JPG
:7head:
fill your tubes with sand to prevent them from caving at the bends. I've got a similar one from Harbor Freight - but it doesn't have those handy feet to set it sideways!
Do they have any more???
oh,,this would be cool...i could bend up a new-higher one for those track days. what sizes did it accomidate?
Bob, I have the HF version of that, and it kinks tubes like there is no tomorrow :( It will probably work if filled with sand.
Southwind, If you want to do tight colapse free bends, go with http://www.jd2.com/ . That's what Arya used for my roll bar, and the results are fantastic. No sand filling needed, and very accurate bends.
For more free flowing curves (LARGE radius), you need a 3 roller bender, but those are $1000...
Type in Portable-10-Ton-Hydraulic-Pipe-Tube-Bender on Ebay. It comes with dies from 1/2' - 2". I'm going to try the sand. I have some real thin wall tubing to bend. Do you wet the sand and then pack it in or do you use it dry?
You're supposed to use it dry - especially if you're gonna heat the tube. I tried bending light (.050) and heavy (.120) tubing with that, and gave up on it. As I said before, didn't try sand.
I haven't bent any large diameter tubing, only smaller stuff, but that "bending tube" link is a terriffic reference. It makes the layout, bend set points etc., almost idiot proof.
Thanks for the link, BusaLoco.
I''d love to have a nice tube bender, but so far only have the need to make one bend of about 90 degrees in a 1" OD tube where I need a center line radius of 5.5" or fairly close to. I have a hard time justifying spending the kind of money for a bender with die to make a desent bend for the sake of 1 bend. I had thought about looking for a shop with a tube bender but I fear my need for the specific bend radius which seems large for the size of tube will be a tough find. I also thought about using an electrical conduit bender but fear they won't be strong enough and/or will kink the tube.
Any thoughts or suggestions that won't break the bank?
I made a lot of bends in heavywall electrical conduit as an apprentice electrician, so I believe you could check the radius of the benders available at Home Depot. It may be a cheap solution to your needs.
My little bender
About $8 in wood, some scrap metals for handles, some bolts and nuts
You'll need a router, radius arm, and a 1/2" cove bit.
As some have discovered, a pipe bender does not work as well as a tubing bender. I am tempted myself for the cost, but the kinks most leave won't pass tech from what I am told.
  • 3 weeks later...
Meccomcorp.com (Detroit, MI)
Ask these guys to do it, they are great and can have almost anything with in a day or two.
They bent my roll bar and I have to admit the bends are as perfect as I can measure with a Stanley tape measure.
Tim
Bob, I fear the bender you bought will be no better than the "pipe kinker" (as they're affectionately known in the fabrication world) that you can buy at Harbor Freight.
I will soon have my JD2 bender in MD though. If you need any structurally critical bends done, I will be more than happy to help you out. That goes for anyone. I've been trying to work out a pricing structure for bending things for people. I'm thinking $20/bend with the price getting cheaper if you need multiple bends etc. Currently I have a 1" die and a 1.75" die, but will be acquiring more as needed.
If any of you need things bent around the country let me know. There's a fairly active bunch of fabricators on pirate4x4.com (where the bending tutorial is hosted) and I may be able to find someone in your area that can help you out.
Ary
