Are there any standard bolt patterns for mounting steering wheels?
The one I bought needs to be drilled, and I'm not ready to replace my steering shaft assembly this time around, so I'm just going to adapt it to my existing assembly.
I want to drill it, so in the future, it'll be compatible with off the shelf stuff.
Hi Mazda,
I think the Momo, Sparco, OMP, and maybe some others use a 6-bolt x 2.75" (or 70mm) pattern. I think some other wheels use a 5-bolt (Grant?) or 3-bolt pattern (some of the racing stuff/karts), but are not as common.
Hope this helps, Bruce :7drive:
Hi Mazda,
K. Is 70 mm the diameter of the pattern or the radius? also, do you know what size holes (even roughly)?
Mazda,
The 70mm dimension is the diameter. All my wheels with that pattern are held on with M5-0.8 countersunk screws so they should be 5mm.
Bruce :7drive:
