it's hard to tell from this pic... is the only difference the cross member? and is the cross member in the same plane as the roll bar?
http://www.usa7s.com/forum/uploads/slngsht/2005-06-30_073801_2005-06-29_000251_Joe_and_Rotus.jpg
There are two going to the rear and the cross brace. The tubing thickness is also checked by a little hole that is drilled in the roll bar
You can probably find the info by doing a search for the SCCA roll bar specs.
Joe
